Hi all,
Here is my new inquiry:
I am trying to get the user to add a graphic marker using. I would imagine two text boxes as input values and a simple button GO to add the graphic and then zoom to graphic. Here is what I have so far, My fiddle.
Thank you for your help,
Alex
Alex,
You forgot several requires:
<!DOCTYPE html> <html> <head> <title>Simple Map</title> <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css"> <script src="http://js.arcgis.com/3.10/"></script> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } body { background-color: #FFF; overflow: hidden; font-family: "Trebuchet MS"; } </style> <script> var map; require(["esri/map", "esri/symbols/SimpleLineSymbol", "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/Color", "dojo/on", "dojo/dom", "esri/geometry/Point", "dojo/domReady!" ], function(Map, SimpleLineSymbol, Graphic, SimpleMarkerSymbol, Color, on, dom, Point) { map = new Map("map", { basemap: "topo", center: [-122.45, 37.75], // longitude, latitude zoom: 13 }); var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 15, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 255, 0.5]), 8 ), new Color([0, 0, 255]) ); on(dom.byId("go"), "click", coordinates); function coordinates() { console.log("got here") var lat = document.getElementById("sel_lat").value var long = document.getElementById("sel_long").value var mp = new Point(long, lat); var graphic = new Graphic(mp, symbol); map.graphics.add(graphic); } }); </script> </head> <body> <div id="map">Tag Long:<input id="sel_long" type="text"> <br /> Tag Lat:<input id="sel_lat" type="text"> <br /> <button id="go">GO</button> </div> </body> </html>
try below this...
<SPAN class="kwd" style="color: #00008b; background: transparent;">function</SPAN><SPAN class="pln" style="background: transparent;"> onQueryComplete</SPAN><SPAN class="pun" style="background: transparent;">(</SPAN><SPAN class="pln" style="background: transparent;">returnedPointFeatureSet</SPAN><SPAN class="pun" style="background: transparent;">){</SPAN><SPAN class="pln" style="background: transparent;"><BR /> </SPAN><SPAN class="kwd" style="color: #00008b; background: transparent;">var</SPAN><SPAN class="pln" style="background: transparent;"> featureSet </SPAN><SPAN class="pun" style="background: transparent;">=</SPAN><SPAN class="pln" style="background: transparent;"> returnedPointFeatureSet </SPAN><SPAN class="pun" style="background: transparent;">||</SPAN><SPAN class="pln" style="background: transparent;"> </SPAN><SPAN class="pun" style="background: transparent;">{};</SPAN><SPAN class="pln" style="background: transparent;"><BR /> </SPAN><SPAN class="kwd" style="color: #00008b; background: transparent;">var</SPAN><SPAN class="pln" style="background: transparent;"> features </SPAN><SPAN class="pun" style="background: transparent;">=</SPAN><SPAN class="pln" style="background: transparent;"> featureSet</SPAN><SPAN class="pun" style="background: transparent;">.</SPAN><SPAN class="pln" style="background: transparent;">features </SPAN><SPAN class="pun" style="background: transparent;">||</SPAN><SPAN class="pln" style="background: transparent;"> </SPAN><SPAN class="pun" style="background: transparent;">[];</SPAN><SPAN class="pln" style="background: transparent;"><BR /><BR /> </SPAN><SPAN class="kwd" style="color: #00008b; background: transparent;">var</SPAN><SPAN class="pln" style="background: transparent;"> extent </SPAN><SPAN class="pun" style="background: transparent;">=</SPAN><SPAN class="pln" style="background: transparent;"> esri</SPAN><SPAN class="pun" style="background: transparent;">.</SPAN><SPAN class="pln" style="background: transparent;">graphicsExtent</SPAN><SPAN class="pun" style="background: transparent;">(</SPAN><SPAN class="pln" style="background: transparent;">features</SPAN><SPAN class="pun" style="background: transparent;">);</SPAN><SPAN class="pln" style="background: transparent;"> <BR /> </SPAN><SPAN class="kwd" style="color: #00008b; background: transparent;">if</SPAN><SPAN class="pun" style="background: transparent;">(!</SPAN><SPAN class="pln" style="background: transparent;">extent </SPAN><SPAN class="pun" style="background: transparent;">&&</SPAN><SPAN class="pln" style="background: transparent;"> features</SPAN><SPAN class="pun" style="background: transparent;">.</SPAN><SPAN class="pln" style="background: transparent;">length </SPAN><SPAN class="pun" style="background: transparent;">==</SPAN><SPAN class="pln" style="background: transparent;"> </SPAN><SPAN class="lit" style="color: #800000; background: transparent;">1</SPAN><SPAN class="pun" style="background: transparent;">)</SPAN><SPAN class="pln" style="background: transparent;"> </SPAN><SPAN class="pun" style="background: transparent;">{</SPAN><SPAN class="pln" style="background: transparent;"><BR /> </SPAN><SPAN class="kwd" style="color: #00008b; background: transparent;">var</SPAN><SPAN class="pln" style="background: transparent;"> point </SPAN><SPAN class="pun" style="background: transparent;">=</SPAN><SPAN class="pln" style="background: transparent;"> features</SPAN><SPAN class="pun" style="background: transparent;">[</SPAN><SPAN class="lit" style="color: #800000; background: transparent;">0</SPAN><SPAN class="pun" style="background: transparent;">];</SPAN><SPAN class="pln" style="background: transparent;"><BR /> map</SPAN><SPAN class="pun" style="background: transparent;">.</SPAN><SPAN class="pln" style="background: transparent;">centerAndZoom</SPAN><SPAN class="pun" style="background: transparent;">(</SPAN><SPAN class="pln" style="background: transparent;">point</SPAN><SPAN class="pun" style="background: transparent;">,</SPAN><SPAN class="pln" style="background: transparent;"> </SPAN><SPAN class="lit" style="color: #800000; background: transparent;">12</SPAN><SPAN class="pun" style="background: transparent;">);</SPAN><SPAN class="pln" style="background: transparent;"><BR /> </SPAN><SPAN class="pun" style="background: transparent;">}</SPAN><SPAN class="pln" style="background: transparent;"> <BR /> </SPAN><SPAN class="kwd" style="color: #00008b; background: transparent;">else</SPAN><SPAN class="pln" style="background: transparent;"> </SPAN><SPAN class="pun" style="background: transparent;">{</SPAN><SPAN class="pln" style="background: transparent;"><BR /> map</SPAN><SPAN class="pun" style="background: transparent;">.</SPAN><SPAN class="pln" style="background: transparent;">setExtent</SPAN><SPAN class="pun" style="background: transparent;">(</SPAN><SPAN class="pln" style="background: transparent;">extent</SPAN><SPAN class="pun" style="background: transparent;">,</SPAN><SPAN class="pln" style="background: transparent;"> </SPAN><SPAN class="kwd" style="color: #00008b; background: transparent;">true</SPAN><SPAN class="pun" style="background: transparent;">);</SPAN><SPAN class="pln" style="background: transparent;"><BR /> </SPAN><SPAN class="pun" style="background: transparent;">}</SPAN><SPAN class="pln" style="background: transparent;"><BR /></SPAN><SPAN class="pun" style="background: transparent;">}</SPAN>
Also - avoid using 'long' as a variable name (line 57) as it is a reserved word in JavaScript.
Thank you Robert! It works great! I am trying to apply code for an automatic zoom to graphic suggested above by vtammineni.
Thank you, I did not know. Will keep that in mind!
Did you figure out the zoom part?
Hi Robert,
I did figure it out last evening thanks to Vankata's code above.
All I really had to do was to use this:
map.centerAndZoom(mp, 9);
So my function would be:
function coordinates() { console.log("Coordinates") var lat = document.getElementById("sel_lat").value var longitude = document.getElementById("sel_long").value var coord = webMercatorUtils.lngLatToXY(longitude, lat); var mp = new Point(longitude, lat); var graphic = new Graphic(mp, symbol); map.graphics.add(graphic); map.centerAndZoom(mp, 9); } }
Thank you again for your help!
