I am using esri's Explorer App on iPad, and in the newest updated the hyperlinks in my attribute table no longer show up as hyperlinks, and are not functioning the same way before the update. Is this a known issue, or is there a new way to format hyperlinks?
img_0342 is before the update
file is after the update.
Hi Mark..
I have noticed other issues with the Explorer app since the mid July release. Many of my fields that would display value in the app previously return "-" now. I have attached a image (image1.png). You will notice the - in the fields that have data (owner, address, city state zip). The fields with no data (lot) show blank. Any ideas? This has happen in numerous services that I use. The data shows correctly in ArcGIS Online web maps and applications, but not on the explorer app.
You can view the app, it is publicly shared. Search for Redmond Infrastructure.
The search option for data or Find Locations option for layer has stopped functioning as well. I have attached a screen shot for the layers I have set up in the Find Locations. Doesn't work.
What happened to groups at the app level.
Thank you,
Mark Chambers
City of Redmond, OR
It is in the App Store now.
Mark
Sweet. So that eliminates the work around and it will work like it did before?
Philip B. Slater
GIS / IT Specialist
Excellent, when can we expect the next update for the Explorer App?
Craig,
Hyperlinking from feature attributes will be restored in the next Explorer for ArcGIS update.
One of the users in our organization also reported this. A tap will yield search results, and clicking on a feature yields a list of attributes. But by and large it appears as though the attribute values were null, when they are not. When viewed in a browser, with pop-ups enabled, the attribute values can be seen just fine. I do want to add that the GIS web services that are in the ArcGIS.com map are http, not https, and access our ArcGIS Server with authentication required. Perhaps there is a problem with the iPad app accessing http services through an organizational account?
I have same issue. No answers from ESRI yet....
