I would like to populate field attributes in dojo combobox and zoom to the selected feature on selected Index changed. any way to achieve this?
Richard,
Here is a thread that answers this question with sample code https://community.esri.com/message/399170#399170
Thank you Robert the link was very helpful. But, now I am having a little issue.
In my case, I have 3 comboboxes populated from 3 different layers and I would like to use the same function (app ={
zoomRow:
for all 3 comboboxes. I thought about using the switch case depending on the ComboBox id but no success.
is there a way around this?
Here is a sample that show how to reuse the zoomRow for two different comboboxes:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>Drop Down Test</title> <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css"> <style> html, body, #mainWindow { height: 100%; width: 100%; margin: 0; padding: 0; } body { background-color: #FFF; overflow: hidden; font-family: "Trebuchet MS"; } #header { height: 3%; overflow: auto; } </style> <script> var dojoConfig = { parseOnLoad: true }; </script> <script src="http://js.arcgis.com/3.10/"></script> <script> var map; require([ "esri/map", "dojo/on", "esri/tasks/query", "esri/layers/FeatureLayer", "dojo/store/Memory", "dojo/_base/array", "dojo/_base/lang", "esri/request", "dojo/json", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/form/Button", "dijit/form/ComboBox", "dojo/domReady!" ], function( Map, on, Query, FeatureLayer, Memory, array, lang, esriRequest, json ) { map = new Map("map", { basemap: "topo", center: [-120.1883, 37.0868], zoom: 6 }); var zipcodes = new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/california-zip-codes-census-2010/FeatureServer/0", { mode: FeatureLayer.MODE_SELECTION, outFields: ["*"] }); map.addLayers([zipcodes]); map.on("layers-add-result", lang.hitch(this, function(){ var url = "http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/california-zip-codes-census-2010/FeatureServer/0/generateRenderer"; var classificationDef = {"type":"uniqueValueDef","uniqueValueFields":["ZCTA5CE10"]}; var classificationDef2 = {"type":"uniqueValueDef","uniqueValueFields":["GEOID10"]}; var str = json.stringify(classificationDef); var str2 = json.stringify(classificationDef2); esriRequest({ url:url, content:{ classificationDef:str, f:'json' }, handleAs:'json', callbackParamName:'callback', timeout:15000 }).then(lang.hitch(this,function(response){ var uniqueValueInfos = response && response.uniqueValueInfos; if(uniqueValueInfos){ var store2 = new Memory({data:[]}); dijit.byId("uniqueValuesSelect").set('store',store2); var data = array.map(uniqueValueInfos,lang.hitch(this,function(info,index){ var value = info.value; value = parseFloat(value); var dataItem = { id:index, name:value }; return dataItem; })); store2 = new Memory({data:data}); dijit.byId("uniqueValuesSelect").set('store',store2); } }),lang.hitch(this,function(error){ console.error(error); })); esriRequest({ url:url, content:{ classificationDef:str2, f:'json' }, handleAs:'json', callbackParamName:'callback', timeout:15000 }).then(lang.hitch(this,function(response){ var uniqueValueInfos2 = response && response.uniqueValueInfos; if(uniqueValueInfos2){ var store3 = new Memory({data:[]}); dijit.byId("uniqueValuesSelect2").set('store',store3); var data2 = array.map(uniqueValueInfos2,lang.hitch(this,function(info,index){ var value2 = info.value; //value2 = parseFloat(value2); var dataItem2 = { id:index, name:value2 }; return dataItem2; })); store3 = new Memory({data:data2}); dijit.byId("uniqueValuesSelect2").set('store',store3); } }),lang.hitch(this,function(error){ console.error(error); })); })); app = { zoomRow: function(id, which){ zipcodes.clearSelection(); var query = new Query(); if(which == "zip"){ query.where = "ZCTA5CE10='" + (id).toString() + "'"; }else if(which == "geo"){ query.where = "GEOID10='" + (id).toString() + "'"; } console.info(query.where); query.returnGeometry = true; zipcodes.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) { var thePoly = features[0].geometry; var theExtent = thePoly.getExtent().expand(2); //Zoom out slightly from the polygon's extent map.setExtent(theExtent); }); } }; }); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;"> <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="overflow:hidden;border:none;border-bottom: 3px solid #CC9900;font-family: Windows;font-size:14pt; color: #FFFFFF;background: #000000; "> Select a California Zip Code and zoom to it on the map: <input id="uniqueValuesSelect" data-dojo-type="dijit.form.ComboBox" value="Zipcode" onchange="app.zoomRow(document.getElementById('uniqueValuesSelect').value, 'zip');" /> <input id="uniqueValuesSelect2" data-dojo-type="dijit.form.ComboBox" value="GEOID10" onchange="app.zoomRow(document.getElementById('uniqueValuesSelect2').value, 'geo');" /> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:95%;border:none;padding:0px;margin:0px;"></div> </div> </body> </html>
