Hi, I am an intern at an Gold Mine and was assigned a few goals for my first month. One of them is helping the geologists automate their map making process, because they just don't know what they are doing. I have developed a model that accomplishes this, except not everything displays. I have done everything I could find elsewhere on the Forums (display on map, parameter, and add results of geoprocessing..). My results do work perfectly fine, but the rest of the map that the geologists don't change doesn't display until I uncheck then check display on map, then they display. Would it be easier if I just projected them inside the model, instead of using the pre-projected versions. That would include what I wanted as a result instead of just being inside the model.Thank you,Bleys
