Yes this has been problem for over 4 years now. We have problems with layers with subtypes. I can never add additional categories to subtypes and have them show in the edit templates. I hope Esri can fix this on the next big update push. This has been really hard to deal with over the last 4 years.
If you symbolize the feature class based on the field that have a subtype, than it would populate for you. Here is another link about subtype and collector.
Collector - Default Subtype Values
Hi Tobias,
Sorry I haven't got back to you - but it's just been Christmas hols here so - well, domains and subtypes haven't been on my mind!
"you're talking about just an ArcGIS Online webmap displayed in a web browser, right?"
Yes - that is correct.
Thanks again and I hope your Christmas was good - although a wee bit cooler than around these parts I hear!
"However in the case of a subtype field I don't think that I can as it won't give you the choice of using a field as a subtype if it's not a numeric field. And the information it's representing is not numeric information."
-->You're right, I forgot about that.
I do have an example very similar to yours working, though. When I have some more time I'll look into the details. I'm using ArcGIS Server 10.1 SP1 QIP1. I remember that some of the apps like Collector had this issue for a while, but you're talking about just an ArcGIS Online webmap displayed in a web browser, right?
Thanks for your help! We are making the feature service available via our own ArcGIS Server. For domains I do generally make the code and the description the same - I don't think that there are many instances where you actually need them to be different!
Basically I have a field called ProposedExisting which holds (currently) either a 1 for Proposed and a 2 for Existing
I then have one domain to use for the FeatureType if a feature is classed as Proposed and another for if it is classed as existing. The domains for the FeatureType is working in ArcGIS Online but not the drop-down list for ProposedExisting and - as you say it is only showing the 1 and 2 in this field as well.
Any ideas would be grand.
Is this an ArcGIS Online hosted feature service, or a you making the feature service available via your own ArcGIS Server instance? In case of the former - I don't know off the top of my head. In case of the latter it's possible but I need more info to help you out. In general I recommend making the code and the description identical because of the description-vs.-value issues you observe with some applications associated with ArcGIS Online.
Sorry - no answer but this is exactly what I am trying to sort out as well. No luck so far. I'm just answering this in the hopes that it might trigger something at ESRI... maybe? I'll tackle them about it directly after Christmas.
