Ok so I am used to ArcGIS and trying to force myself to learn all the common items in ArcPro, can someone help direct me where to set up line decorations in ArcPro? I need to add a directionality arrow to the end of my lines. In ArcGIS I would go into the Symbol Property Editor, goto the Line Properties tab, then I could select a line decoration. This would then show a single line with an arrow at the end showing direction.
Where is this in ArcPro? I found line properties and I see you can add effects, one being an arrow effect but I do not want a double line, just the arrow on the end. Anyone know what effect that is or where I should be looking if it is not in the effects?
