So when you define your polygon symbology you change the outline symbology, thickness etc. and the fill colour in the code or define it in the map service. Are these polygons a graphics layer or is it referencing actual data?Not quite sure what that shape is. It looks like three rectangles, would you be able to explain this symbology a little more?
Hi,Please can you clarify the following in more detail. Do you require the green rectangle element specified in your control template to have the geometry of your polygon graphic? In this scenario, if the geometry is different for each polygon where would you like the yellow lines to be positioned? If each polygon geometry always is a rectangle would you require the yellow lines to emerge from the bottom corners of each rectangle?CheersKerrie
