When you say "toolbox commands", are you talking about the exact name of the tool (with proper capitalization)?
for newToolName in arcpy.ListTools(): print newToolName
# # Updates Tools, Functions, Environments & a few Methods from 9.x to "case-sensitive" 10.x # # Note: Rewrites script(s) to hardcoded "ARC10" directory. # # Thoughts: # Can I get a list of all Methods & Properties? # # R.D. Harles # 11-21-10 # import arcpy, os, sys, string # Output directory for updated scripts if not os.path.exists("ARC10"): os.mkdir("ARC10") # Create the master dictionary masterDict={} # Add tools to the masterDict (with and without the toolbox) # Note: The "(" is required because some tools start with the same word as others (e.g. gp.select & gp.selectlayerbylocation) for newToolName in arcpy.ListTools(): # Without toolbox (e.g. clip) masterDict["gp."+newToolName.split("_")[0].lower()+"("] = "arcpy."+newToolName+"(" # With toolbox (e.g. clip_management) masterDict["gp."+newToolName.lower()+"("] = "arcpy."+newToolName+"(" # Add environments to the masterDict for env in arcpy.ListEnvironments(): masterDict["gp."+env.lower()] = "arcpy.env."+env # These don't get listed for some reason? masterDict["gp.overwriteoutput"] = "arcpy.env.overwriteOutput" masterDict["gp.GetParameterAsText"] = "arcpy.env.GetParameterAsText" # Add functions to the masterDict functions = ["AddError","AddFieldDelimiters","AddIDMessage","AddMessage","AddReturnMessage","AddToolbox","AddWarning", "AsShape","CheckExtension","CheckInExtension","CheckOutExtension","CheckProduct","ClearEnvironment", "Command","CopyParameter","CreateObject","CreateRandomValueGenerator","CreateScratchName","CreateUniqueName", "Describe","Exists","GetArgumentCount","GetIDMessage","GetInstallIInfo","GetMaxSeverity","GetMessage", "GetMessageCount","GetMessages","GetParameter","GetParameterAsText","GetParameterCount","GetParameterInfo", "GetParameterValue","GetReturnCode","GetSeverity","GetSeverityLevel","GetSystemEnvironment","ImportToolbox", "InsertCursor","IsSynchronous","ListDatasets","ListEnvironments","ListFeatureClasses","ListFields","ListFiles", "ListIndexes","ListInstallations","ListPrinterNames","ListRasters","ListTables","ListToolboxes","ListTools", "ListVersions","ListWorkspaces","LoadSettings","NumpyArrayToRaster","ParseFieldName","ParseTableName", "ProductInfo","RasterToNumPyArray","RefreshActiveView","RefreshCatalog","RefreshTOC","RemoveToolbox", "ResetEnvironments","ResetProgressor","SaveSettings","SearchCursor","SetParameter","SetParameterAsText", "SetProduct","SetProgressor","SetProgressorLabel","SetProgressorPosition","SetSeverityLevel","TestSchemaLock", "UpdateCursor","Usage","ValidateFieldName","ValidateTableName"] for func in functions: masterDict["gp."+func.lower()] = "arcpy."+func # Add cursor methods to masterDict methods = ["next","reset","newRow","insertRow","updateRow","deleteRow","getValue","isNull","setNull","setValue","getPart","getObject","removeAll","partCount"] for meth in methods: masterDict[meth.lower()] = meth # This isn't going to work. There could be up to 3 replaceable items on one line and only item item per line can be replace the way the script is written. ### Codes and return values ##codesReturnValues = ["ArcView","ArcEditor","ArcInfo","Engine","EngineGeoDB","ArcServer","AlreadyInitalized","Available","Unavailable","NotLicensed","Failed"] ##for crv in codesReturnValues: ## masterDict[crv.lower()] = crv # Add misc to masterDict masterDict["gp = arcgisscripting.create()"] = "" masterDict["gp = arcgisscripting.create(9.3)"] = "" # Loop through python scripts for script in os.listdir(''): if script.endswith('.py'): print "\nProcessing "+script+"..." # Open new file (output to hardcoded "ARC10" directory) wfile = open("ARC10/"+script, "w") count=0 # Read existing script (line by line) for line in open(script).readlines(): # Make the line lower case to ensure match with lower case item lower = line.lower() count=count+1 # Loop through master dictionary for item in masterDict: # Get the key (2nd part of the pair) key = masterDict[item] # Check for a match in the line x = lower.find(item) # Continue if there is a match if x != -1: # Do the search & replace fix = lower.replace(item, key) # Write it (changed line) wfile.write(fix) print " "+script+": (line"+str(count)+") Replacing '"+item+"' with '"+key+"'" break if x == -1: # Write it (unchanged line) wfile.write(line) print " "+script+": (line"+str(count)+") Writing original line: "+line # Close file wfile.close() ## Replace arcgisscripting with arcpy # Open file in read mode file = open("ARC10/"+script, "r") # Read entire file text = file.read() # Closes the read session file.close() file = open("ARC10/"+script, "w") print "\n ...Replacing arcgisscripting with arcpy" file.write(text.replace("arcgisscripting", "arcpy")) file.close() print "\nDone.\n"
