I got an error when I debug the proxy.ashxerror message screenshot is attached.
<serverUrl url ="https://wsbv7/WebGIS/rest/services..."
<serverUrl url ="http://wsbv7/WebGIS/rest/services..."
// This script is added to force the application to certify the SSL script (if for example you have a self certificate on server) System.Net.ServicePointManager.ServerCertificateValidationCallback += delegate(object sender, System.Security.Cryptography.X509Certificates.X509Certificate certificate, System.Security.Cryptography.X509Certificates.X509Chain chain, System.Net.Security.SslPolicyErrors sslPolicyErrors) { return true; };
<serverUrl url ="https://212.147.136.135/ArcGIS/rest/services/DoEHLG/ACTIVITIES/FeatureServer" matchAll="true" dynamicToken="true" host="https://localhost/imds/" userName="USERNAME" password="PASSWORD"> </serverUrl>
esriConfig.defaults.io.alwaysUseProxy = true; featureLayer = new esri.layers.FeatureLayer("https://212.147.136.135/ArcGIS/rest/services/DoEHLG/ACTIVITIES/FeatureServer/0", { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, outFields: ["*"], id: "featureLayer" });
Error: Unable to load proxy.ashx?https://212.147.136.135/ArcGIS/rest/services/DoEHLG/ACTIVITIES/FeatureServer/0/query status:403 http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.3 Line 14
public string GetToken(string uri) { foreach (ServerUrl su in serverUrls) { if (su.MatchAll && uri.StartsWith(su.Url, StringComparison.InvariantCultureIgnoreCase) && su.DynamicToken) { // Code to dynamically get the token string tokenService = string.Format("https://{0}/arcgis/tokens?request=getToken&username={1}&password={2}&expiration=30", su.Host, su.UserName, su.Password); string token; // This script is added to force the application to certify the SSL script (if for example you have a self certificate on server) System.Net.ServicePointManager.ServerCertificateValidationCallback += delegate(object sender, System.Security.Cryptography.X509Certificates.X509Certificate certificate, System.Security.Cryptography.X509Certificates.X509Chain chain, System.Net.Security.SslPolicyErrors sslPolicyErrors) { return true; }; System.Net.WebRequest tokenRequest = System.Net.WebRequest.Create(tokenService); System.Net.WebResponse tokenResponse = tokenRequest.GetResponse(); System.IO.Stream responseStream = tokenResponse.GetResponseStream(); System.IO.StreamReader readStream = new System.IO.StreamReader(responseStream); token = readStream.ReadToEnd(); return token; } else if (su.MatchAll && uri.StartsWith(su.Url, StringComparison.InvariantCultureIgnoreCase)) { return su.Token; } else { if (String.Compare(uri, su.Url, StringComparison.InvariantCultureIgnoreCase) == 0) return su.Token; } } if (mustMatch) throw new InvalidOperationException(); return string.Empty; }
