...by your last statement, you want to 'SUM' point attribute values in the cell (not 'COUNT').Enjoy,Wayne
I see, then the next thing I would check is if the output grid size corresponds with your previous result, in other words, is the size you expect.What is the current status of intallation of your service packs?For example, these problems (and there are more) may or may not be related to your problem, which should have been addressed by service pack 5:NIM068062 - The Point, Polyline, Polygon To Raster tools do not honor the environment cellsize, and when the cellsize is cleared on the dialog, the default value is not filled out.NIM060777 - Point, Polyline, Polygon, Feature To Raster tools crash when output is a fGDB raster.
Also, guess your tech guys know this, that the SPs should be cumulative, meaning if you install SP5 that should get you current. Hope that works...BTW, your spatial reference is right?...it usually helps to check everything - you know the saying, that what you're looking for can be the last place you search. (A corollary to Murphy's law?)Good Luck,Wayne
