I am using ESRI map in my Android app withesriMapVersion = '100.8.0'
The app is crashing due to this error, I don't know why it is happening. May I know the reason for this?
Fatal Exception: com.esri.arcgisruntime.ArcGISRuntimeException: Null pointer
at com.esri.arcgisruntime.internal.jni.CoreMapView.nativeGetMagnifierEnabled(CoreMapView.java)
at com.esri.arcgisruntime.internal.jni.CoreMapView.r(CoreMapView.java:190)
at com.esri.arcgisruntime.internal.h.b.p.t(p.java:304)
at com.esri.arcgisruntime.mapping.view.MapView.isMagnifierEnabled(MapView.java:397)
at com.esri.arcgisruntime.mapping.view.DefaultMapViewOnTouchListener.onLongPress(DefaultMapViewOnTouchListener.java:659)
at com.esri.arcgisruntime.mapping.view.DefaultMapViewOnTouchListener$2.run(DefaultMapViewOnTouchListener.java:176)
at android.os.Handler.handleCallback(Handler.java:873)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:214)
at android.app.ActivityThread.main(ActivityThread.java:7080)
at java.lang.reflect.Method.invoke(Method.java)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:494)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:965)More info:
at com.esri.arcgisruntime.internal.jni.CoreGeoView.nativePause(CoreGeoView.java)
at com.esri.arcgisruntime.internal.jni.CoreGeoView.a(CoreGeoView.java:575)
at com.esri.arcgisruntime.internal.h.b.g.c(g.java:1058)
at com.esri.arcgisruntime.mapping.view.GeoView$RenderingThread.b(GeoView.java:1175)
at com.esri.arcgisruntime.mapping.view.GeoView$RenderingThread.lambda$4H6K_b9I57wxvILOLXOzXwoSpac(GeoView.java)
at com.esri.arcgisruntime.mapping.view.-$$Lambda$GeoView$RenderingThread$BRrsZ2XB9Y4rOvLRx6U82gkIAIs.run(-.java:2)
at com.esri.arcgisruntime.mapping.view.GeoView$RenderingThread.run(GeoView.java:1210)Let me know if need any further info. Thanks in advance.
