Dear all
I want to change the default symbology of area and line tools that comes with measurement widgets in arcgis java script api 4.15.
i want my own custom symbology for both tools area and distance tools.
Thanks.
Nadir,
Here is a snippet:
<SPAN class="comment token">// Create new instance of the Measurement widget</SPAN> <SPAN class="keyword token">const</SPAN> measurement <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Measurement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> measurement<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"activeWidget"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">===</SPAN> <SPAN class="string token">"Distance Measurement"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> evt<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>handleColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.8</SPAN><SPAN class="punctuation token">]</SPAN> evt<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>pathPrimaryColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> evt<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>pathSecondaryColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">128</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">128</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">128</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN>evt<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> evt<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>pathColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> evt<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>handleColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.8</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> evt<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>fillColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0.3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
<!DOCTYPE html><html> <head> <meta charset="utf-8" /> <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" /> <title>Measurement in 2D - 4.15</title>
<style> html, body, #viewDiv { padding: 0; margin: 0; height: 100%; width: 100%; }
#topbar { background: #fff; padding: 10px; }
.action-button { font-size: 16px; background-color: transparent; border: 1px solid #d3d3d3; color: #6e6e6e; height: 32px; width: 32px; text-align: center; box-shadow: 0 0 1px rgba(0, 0, 0, 0.3); }
.action-button:hover, .action-button:focus { background: #0079c1; color: #e4e4e4; }
.active { background: #0079c1; color: #e4e4e4; } </style>
<link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css" /> <script src="https://js.arcgis.com/4.15/"></script>
<script> require([ "esri/views/MapView", "esri/WebMap", "esri/widgets/DistanceMeasurement2D", "esri/widgets/AreaMeasurement2D" ], function(MapView, WebMap, DistanceMeasurement2D, AreaMeasurement2D) { var activeWidget = null;
// load a webmap const webmap = new WebMap({ portalItem: { id: "990d0191f2574db495c4304a01c3e65b" } });
// create the map view const view = new MapView({ container: "viewDiv", map: webmap });
// add the toolbar for the measurement widgets view.ui.add("topbar", "top-right");
document .getElementById("distanceButton") .addEventListener("click", function() { setActiveWidget(null); if (!this.classList.contains("active")) { setActiveWidget("distance"); } else { setActiveButton(null); } });
document .getElementById("areaButton") .addEventListener("click", function() { setActiveWidget(null); if (!this.classList.contains("active")) { setActiveWidget("area"); } else { setActiveButton(null); } });
function setActiveWidget(type) { switch (type) { case "distance": activeWidget = new DistanceMeasurement2D({ view: view });
// skip the initial 'new measurement' button activeWidget.viewModel.newMeasurement();
view.ui.add(activeWidget, "top-right"); setActiveButton(document.getElementById("distanceButton")); break; case "area": activeWidget = new AreaMeasurement2D({ view: view });
view.ui.add(activeWidget, "top-right"); setActiveButton(document.getElementById("areaButton")); break; case null: if (activeWidget) { view.ui.remove(activeWidget); activeWidget.destroy(); activeWidget = null; } break; } }
function setActiveButton(selectedButton) { // focus the view to activate keyboard shortcuts for sketching view.focus(); var elements = document.getElementsByClassName("active"); for (var i = 0; i < elements.length; i++) { elements.classList.remove("active"); } if (selectedButton) { selectedButton.classList.add("active"); } } const measurement = new Measurement(); measurement.watch("activeWidget", function(evt){ if(evt.label === "distanceButton"){ alert("if"); console.info(evt.viewModel.palette); evt.viewModel.palette.handleColor = [255,0,0,0.8] evt.viewModel.palette.pathPrimaryColor = [255,0,0,1]; evt.viewModel.palette.pathSecondaryColor = [128,128,128,1]; }else{ alert("else"); console.info(evt.viewModel.palette); evt.viewModel.palette.pathColor = [255,0,0,1]; evt.viewModel.palette.handleColor = [255,0,0,0.8]; evt.viewModel.palette.fillColor = [255,0,0,0.3]; } }); }); </script> </head>
<body> <div id="viewDiv"></div> <div id="topbar"> <button class="action-button esri-icon-measure-line" id="distanceButton" type="button" title="Measure distance between two or more points" ></button> <button class="action-button esri-icon-measure-area" id="areaButton" type="button" title="Measure area" ></button> </div> </body></html>
the above is me testing code.i applied the which you give it to me.But it not making any effect.
That's because you are using the DistanceMeasurement2D and AreaMeasurement2D and Not the Measurement widget. Didn't you see the errors in the console about the Menasurement? In your code it would look like this:
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">setActiveWidget</SPAN><SPAN class="punctuation token">(</SPAN>type<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">switch</SPAN> <SPAN class="punctuation token">(</SPAN>type<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">case</SPAN> <SPAN class="string token">"distance"</SPAN><SPAN class="punctuation token">:</SPAN> activeWidget <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">DistanceMeasurement2D</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// skip the initial 'new measurement' button</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">newMeasurement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>handleColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.8</SPAN><SPAN class="punctuation token">]</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>pathPrimaryColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>pathSecondaryColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">128</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">128</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">128</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>activeWidget<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setActiveButton</SPAN><SPAN class="punctuation token">(</SPAN>document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"distanceButton"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">case</SPAN> <SPAN class="string token">"area"</SPAN><SPAN class="punctuation token">:</SPAN> activeWidget <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">AreaMeasurement2D</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// skip the initial 'new measurement' button</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">newMeasurement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>pathColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>handleColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.8</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN>viewModel<SPAN class="punctuation token">.</SPAN>palette<SPAN class="punctuation token">.</SPAN>fillColor <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>activeWidget<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setActiveButton</SPAN><SPAN class="punctuation token">(</SPAN>document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"areaButton"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">case</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>activeWidget<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">remove</SPAN><SPAN class="punctuation token">(</SPAN>activeWidget<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> activeWidget<SPAN class="punctuation token">.</SPAN><SPAN class="token function">destroy</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> activeWidget <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hello Robert,
Thank you! This is a good idea, but it seems that the palette property is only present in 2d's measurement widget viewModel, I use DirectLineMeasurement3D widget, which doesn't have palette property in its corresponding viewModel. I output viewModel from the console and don't see any properties related to symbols. Do you have any suggestions? Thank you so much!
Hello!
So I had some trouble changing the default colors for two different measurement tool (a distance line tool and an area measurement tool from the measurement widget) in React.js. This post was SUPER helpful but I want to add a few things. I am using React.js version 17.0.1 running with Node.js v 16.0.0 and the arcgis/core package version 4.24
Hope this helps someone out there! Good luck! You can do it!
have anyone tried to change the colour using the ESM? I created a simple Ex WAB widget for the purposes of being able to control the colour of the measurement graphics but I can't see the palette property on the viewModel.
Also, is it possible to turn off the map measurement labels?
I found that someone submitted an idea:
https://community.esri.com/t5/arcgis-javascript-maps-sdk-ideas/measurement-2d-areameasurement2dviewmodel-and/idc-p/1207712#M165
So hopefully available OOTB soon.
Thank you
Hello @craragon77 @RobertScheitlin__GISP ! Thanks for sharing this, but I am testing it and palette attribute does not exist in viewModel in esri version 4.28 when I console log it.
