parameters.Add(new GPFeatureRecordSetLayer("Draw_Polygon", args.Geometry));
parameters.Add(new GPFeatureRecordSetLayer("Draw_Polygon", new FeatureSet( (Map.Layers["MyGraphicsLayer"] as GraphicsLayer).Graphics )));
private void CreateGeoPoly_Click(object sender, RoutedEventArgs e) { //Gives users ability to draw poly MyDrawObject = new Draw(Map) { DrawMode = DrawMode.Polygon, IsEnabled = true, FillSymbol = LayoutRoot.Resources["ClipFeaturesFillSymbol"] as ESRI.ArcGIS.Client.Symbols.FillSymbol }; //Start MyDrawObject_DrawComplete, which turns the drawn poly into a graphic MyDrawObject.DrawComplete += MyDrawObject_DrawComplete; }
private void MyDrawObject_DrawComplete(object sender, DrawEventArgs args) { //Disable the drawing tool MyDrawObject.IsEnabled = false; //Start processing time bar ProcessingTextBlock.Visibility = Visibility.Visible; _processingTimer.Start(); //Assign the graphic draw to a graphiclayer, the graphic layer is defined in xaml GraphicsLayer graphicsLayer = Map.Layers["MyGraphicsLayer"] as GraphicsLayer; //Ready the graphic to assign the graphic to the parameter Graphic graphic = new Graphic() { Symbol = LayoutRoot.Resources["ClipFeaturesFillSymbol"] as ESRI.ArcGIS.Client.Symbols.FillSymbol, Geometry = args.Geometry }; //add graphic graphicsLayer.Graphics.Add(graphic); }
If your number of input geometry is not defined you can also consider to use a FeatureSetLayer as input.
private void RunGeoPolyButton_Click(object sender, RoutedEventArgs e) { //Declare GP Task and URL Geoprocessor geoprocessorTask = new Geoprocessor("http://servername/ArcGIS/rest/services/GPServer/CreatePoly"); geoprocessorTask.UpdateDelay = 5000; //When Task Completes call method GeoprocessorTask_JobCompleted geoprocessorTask.JobCompleted += GeoprocessorTask_JobCompleted; //Input Parameters List<GPParameter> parameters = new List<GPParameter>(); parameters.Add(new GPFeatureRecordSetLayer("Draw_Polygon", args.Geometry)); geoprocessorTask.SubmitJobAsync(parameters);
all the tasks seem to be kicking off by using the DrawEventArgs args complete call.
I was wondering can the tasks take more than one input ...more than one poly,line, or point?
