Is there a built-in service or application on AGOL to do Clip-Zip-Ship? I want to know what is the easiest way with esri tools to do clip-zip-ship on an interactive map online. Thanks !
Hi alexis trépanier,
Have a look into the Extract Data—ArcGIS Online Help | Documentation widget. It gives you multiple options for clipping data by extent or a drawn area. This assumes that the layer has the ability to be exported enabled. I hope this answered your question.
Shane
It would be best to ask this in the ArcGIS Online space for a better chance at getting an answer/suggestions from users in that space! Hope this helps.
Hi Shane !
Thanks for the answer. So maybe I'm still a little uncertain of the different ESRI products, but I feel like extract tool need you to have access to the server to retrieve the data. What I would like is to publish a map with some layers on an open website and for people to be able to download the data with that 'Extract Data' tool.
I have low experience with ESRI products could you help me understand if that's possible and what products I would need?
Thanks !!
Have a look into the Configure security settings—ArcGIS Online Help | Documentation. There is a number of settings such as Sharing, Searching and Allow Origins that can be configured to enable use within the public.
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
