gridNoColumnSets.set("columnSets", columnExample1); //gridNoColumnSets.set("columnSets", columnExample2);
function selectState(e) { // select the feature var fl = app.map.getLayer("NAME"); var features = fl.getSelectedFeatures(); var symbol = fl.getSelectionSymbol(); var id = parseInt(e.target.innerHTML); var selectedGraphic; arrayUtils.forEach(features, function(feature){ if(feature.attributes.OBJECTID === id){ selectedGraphic = feature; } feature.setSymbol(symbol); }); var mySymbol = new SimpleMarkerSymbol().setOutline(null).setColor("#AEC7E3"); selectedGraphic.setSymbol(mySymbol); app.map.centerAt(selectedGraphic.geometry.getExtent().getCenter()); }
query.objectIds = [parseInt(e.target.innerHTML)];
var columnExample2 = [ [ [ {label: 'id', field: 'id', sortable: false, formatter: function () { return '<img src="images/marker.png"/>'; }, get: function (object) { return object["id"]; } }, {label: 'access', field: 'ACCESSAREA'} ], [ {label: 'location', field: 'LOCATION', colSpan: 2, sortable: false} ] ], ];
dataGrid.on(".dgrid-row:click", gridSelect); dataGrid.on("show", function () { dataGrid.resize(); }); dataGrid.on(mouseUtil.enterRow, gridEnter);
//this highlights the graphic function gridEnter(e) { map.graphics.clear(); var gridId = e.currentTarget.id; var selectedGrid = dijit.byId(gridId); var row = selectedGrid.row(e); graphicHighlight = findGraphicByAttribute(row.data); if (graphicHighlight !== null) { switch (graphicHighlight.geometry.type) { case "point": case "multipoint": map.graphics.add(new esri.Graphic(graphicHighlight.geometry, symbolHighlightPoint)); break; case "polyline": map.graphics.add(new esri.Graphic(graphicHighlight.geometry, symbolHighlightPolyline)); break; case "polygon": case "extent": map.graphics.add(new esri.Graphic(graphicHighlight.geometry, symbolHighlightPolygon)); break; } } } //this "flashes" the graphic function gridSelect(e) { var graphicFlash; var gridId = e.currentTarget.id; var selectedGrid = dijit.byId(gridId); var row = selectedGrid.row(e); graphicHighlight = findGraphicByAttribute(row.data); if (graphicHighlight !== null) { switch (graphicHighlight.geometry.type) { case "point": case "multipoint": graphicFlash = new esri.Graphic(graphicHighlight.geometry, symbolFlashPoint) break; case "polyline": graphicFlash = new esri.Graphic(graphicHighlight.geometry, symbolFlashPolyline); break; case "polygon": case "extent": graphicFlash = new esri.Graphic(graphicHighlight.geometry, symbolFlashPolygon); break; } map.graphics.add(graphicFlash); } var shape = graphicFlash.getDojoShape(); var animStroke = fx.animateStroke({ shape: shape, duration: 500, color: { end: new dojo.Color([0, 0, 0, 0]) } }); var animFill = fx.animateFill({ shape: shape, duration: 500, color: { end: new dojo.Color([0, 0, 0, 0]) } }); var anim = dojo.fx.combine([animStroke, animFill]).play(); var animConnect = dojo.connect(anim, "onEnd", function () { map.graphics.remove(graphicFlash); }); } function findGraphicByAttribute(attributes) { for (i = 0; i < layerResultsGraphic.graphics.length; i++) { if (JSON.stringify(layerResultsGraphic.graphics.attributes) === JSON.stringify(attributes)) { return layerResultsGraphic.graphics; } } return null; }
Jay, I am trying to help you as best I can without actually doing your work for you.Please reread my previous posts to find the answer to your question.What does e.target.innerHTML equal in this last sample?
var id1 = parseInt(e.currentTarget.id)
var id1 = e.currentTarget.id;
var gridId = e.currentTarget.id; var selectedGrid = dijit.byId(gridId); alert(selectedGrid);
function selectState(e) { alert("select the feature"); var fl = app.map.getLayer("NAME"); var features = fl.getSelectedFeatures(); var symbol1 = fl.getSelectionSymbol(); var id1 = parseInt(e.currentTarget.id); var selectedGraphic1; arrayUtils.forEach(features, function(feature){ if(feature.attributes.OBJECTID === id1){ selectedGraphic1 = feature; } feature.setSymbol(symbol1); }); var mySymbol1 = new SimpleMarkerSymbol().setOutline(null).setColor("#AEC7E3"); selectedGraphic1.setSymbol(mySymbol1); app.map.centerAt(selectedGraphic1.geometry.getExtent().getCenter()); }
Thanks Ken....I I tweaked the JSFiddle to reflect your example sand now when I click the map I dont get any return to the grid...thoughts?http://jsfiddle.net/Jaykapalczynski/HjMB9/17/
You should get into the habit of using debugging tools like Firebug. These are the errors from your Fiddle[ATTACH=CONFIG]33445[/ATTACH]For the mouseUtils error, you'll have to add the "dgrid/util/mouse" module in your require statement.
Uncaught TypeError: Cannot read property 'row' of undefined (index):807 gridEnter (index):807 (anonymous function) mouse.js:2 (anonymous function) init.js:215 Uncaught TypeError: Cannot read property 'row' of undefined (index):836 2 Uncaught TypeError: Cannot read property 'row' of undefined
This line var gridId = e.currentTarget.id;is returning the name of the div that the grid is stored in, not the grid itself. So then this linevar selectedGrid = dijit.byId(gridId);returns an "undefined"
var fl = app.map.getLayer("NAME"); var features = fl.getSelectedFeatures(); var symbol1 = fl.getSelectionSymbol(); // var id1 = e.current.id; // var id1 = e.currentTarget.id; // var id1 = e.current.objectID; // var id1 = e.currentTarget.objectID; // var gridId= e.currentTarget.objectID; // var id1= parseInt(gridId); var selectedGraphic1; arrayUtils.forEach(features, function(feature){ if(feature.attributes.OBJECTID === id1){ selectedGraphic1 = feature; } feature.setSymbol(symbol1); });
var columnExample2 = [ [ [ {label: 'id', field: 'id', sortable: false, formatter: function () { return '<img src="images/Identify.png"/>'; }, get: function (object) { return object["objectID"]; } }, {label: 'access', field: 'ACCESSAREA', sortable: true} ], [ {label: 'waterbody', field: 'WATERBODY', colSpan: 2} ], [ {label: 'location', field: 'LOCATION', colSpan: 2, sortable: false} ] ], ];
Take a look at this site where a feature is highlighted from a grid. The feature can be highlighted by moving the mouse over the row in the grid or by clicking on the row. When the grid (dataGrid) is created, I add on listeners: //this highlights the graphic function gridEnter(e) { map.graphics.clear(); var gridId = e.currentTarget.id; var selectedGrid = dijit.byId(gridId); var row = selectedGrid.row(e); graphicHighlight = findGraphicByAttribute(row.data); if (graphicHighlight !== null) { switch (graphicHighlight.geometry.type) { case "point": case "multipoint": map.graphics.add(new esri.Graphic(graphicHighlight.geometry, symbolHighlightPoint)); break; case "polyline": map.graphics.add(new esri.Graphic(graphicHighlight.geometry, symbolHighlightPolyline)); break; case "polygon": case "extent": map.graphics.add(new esri.Graphic(graphicHighlight.geometry, symbolHighlightPolygon)); break; } } }
