I have written a Python module that handles the pre-processing and ArcHydro. As part of the pre-processing it generates a set of rasters that are saved in a separate directory. The following rasters are then used as input to generate Feature Classes that are then saved in a File Geodatabase in a separate directory. I have split the following module into two functions, one for the rasters and the other for the Feature Classes. I then have a main function below that calls both the functions to pre-process the rasters and feature classes. In the first function I have set the workspace environment to the rasters directory that works well. The problem that I have is within the second function where I need to access the rasters as input but need to alter the output so that the Feature Classes are saved into the File Geodatabase without having to specify the output path manually for each Feature Class. I have attached below the directory structure of the rasters folder as well as the File Geodatabase where the Feature Classes are saved, as well as my current code.
Any advice in how to handle separate input and output workspace environments without having to specify the paths manually will be appreciated.
<SPAN class="string token">'''
Created on March 13, 2017
ArcHydro Main Model
@author: PeterW
'''</SPAN>
<SPAN class="comment token"># import system modules and site-packages</SPAN>
<SPAN class="keyword token">from</SPAN> pathlib <SPAN class="keyword token">import</SPAN> Path
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> ArcHydroTools
<SPAN class="comment token"># check out extensions and set environment settings</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CheckOutExtension<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Spatial"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">rasters_main</SPAN><SPAN class="punctuation token">(</SPAN>rasters_workspace<SPAN class="punctuation token">,</SPAN> dem<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">""" Create Rasters as part of ArcHydro Pre-processing"""</SPAN>
<SPAN class="comment token"># set current workspace</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> rasters_workspace
<SPAN class="comment token"># create Fil Sinks raster</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Fill Sinks"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>FillSinks<SPAN class="punctuation token">(</SPAN>dem<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"fil"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># create Flow Direction raster</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Flow Direction"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>FlowDirection<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"fil"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"fdr"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># create Flow Accumulation raster</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Flow Accumulation"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>FlowAccumulation<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"fdr"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"fac"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># create Stream Threshold raster</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Flow Stream Threshold"</SPAN><SPAN class="punctuation token">)</SPAN>
maxcellsResult <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetRasterProperties_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"fac"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"MAXIMUM"</SPAN><SPAN class="punctuation token">)</SPAN>
maxcells <SPAN class="operator token">=</SPAN> maxcellsResult<SPAN class="punctuation token">.</SPAN>getOutput<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{} Maximum Cells"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>maxcells<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
stream_threshold_numcells <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>maxcells<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">*</SPAN><SPAN class="number token">0.03125</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">100</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"{} Stream Threshold"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>stream_threshold_numcells<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Create Stream Definition raster</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Stream Definition"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>StreamDefinition<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"fac"</SPAN><SPAN class="punctuation token">,</SPAN> stream_threshold_numcells<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"str"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Create Stream Link raster</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Stream Segmentation"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>StreamSegmentation<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"str"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"fdr"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"strlnk"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Create Catchment Grid raster</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Catchment Grid Delineation"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>CatchmentGridDelineation<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"fdr"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"strlnk"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"cat"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">vector_main</SPAN><SPAN class="punctuation token">(</SPAN>fgdb_workspace<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Create Feature Classes as part of
<SPAN class="comment token"># Create Catchment</SPAN>
catchments <SPAN class="operator token">=</SPAN> <SPAN class="string token">"{0}\\{1}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>Path<SPAN class="punctuation token">(</SPAN>fgdb_workspace<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Layers"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Catchment"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># repeating output workspace</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Catchment Polygon"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>CatchmentPolyProcessing<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"cat"</SPAN><SPAN class="punctuation token">,</SPAN> catchments<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Create DrainageLine</SPAN>
drainageline <SPAN class="operator token">=</SPAN> <SPAN class="string token">"{0}\\{1}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>Path<SPAN class="punctuation token">(</SPAN>fgdb_workspace<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Layers"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"DrainageLine"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># repeating output workspace</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing DrainageLine"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>DrainageLineProcessing<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"strlnk"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"fdr"</SPAN><SPAN class="punctuation token">,</SPAN>
drainageline<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Create AdjointCatchment</SPAN>
adjointcatchment <SPAN class="operator token">=</SPAN> <SPAN class="string token">"{0}\\{1}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>Path<SPAN class="punctuation token">(</SPAN>fgdb_workspace<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Layers"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"AdjointCatchment"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># repeating output workspace</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Processing Adjoint Catchment"</SPAN><SPAN class="punctuation token">)</SPAN>
ArcHydroTools<SPAN class="punctuation token">.</SPAN>AdjointCatchment<SPAN class="punctuation token">(</SPAN>drainageline<SPAN class="punctuation token">,</SPAN> catchments<SPAN class="punctuation token">,</SPAN>
adjointcatchment<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CheckInExtension<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Spatial"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">main</SPAN><SPAN class="punctuation token">(</SPAN>rasters_workspace<SPAN class="punctuation token">,</SPAN> dem<SPAN class="punctuation token">,</SPAN> fgdb_workspace<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
rasters_main<SPAN class="punctuation token">(</SPAN>rasters_workspace<SPAN class="punctuation token">,</SPAN> dem<SPAN class="punctuation token">)</SPAN>
vector_main<SPAN class="punctuation token">(</SPAN>fgdb_workspace<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> __name__ <SPAN class="operator token">==</SPAN> <SPAN class="string token">"__main__"</SPAN><SPAN class="punctuation token">:</SPAN>
main<SPAN class="punctuation token">(</SPAN>rasters_workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"E:\Projects\2016\01_Bertrand_Small_Projects\G113268\ArcHydro\Model03\Layers03"</SPAN><SPAN class="punctuation token">,</SPAN>
dem <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"E:\Projects\2016\01_Bertrand_Small_Projects\G113268\ArcHydro\DEM2\raw"</SPAN><SPAN class="punctuation token">,</SPAN>
fgdb_workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"E:\Projects\2016\01_Bertrand_Small_Projects\G113268\ArcHydro\Model03\Model03.gdb"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
