How do you show attachments in the list in Operations Dashboard? I would like to include my photo attachments in the list found in operations dashboard. Similar to a dashboard you created for Property Viewer. https://business.maps.arcgis.com/apps/opsdashboard/index.html#/cae46b785871424fb7453ae51cbc7a83
To add the photo to the side of the items in the List.
Go to Configure > List.
Then click on the Photo Icon.
Almost everything in this list is tagged from items in the attribute table. in the Photo icon options you will see a URL text box. Its asking for the URL of the photos related to your items. I used the attribute field in my data that has the URL for each site photo. My is called {IMAGE_URL}. Yours may be different.
I used the Alignment Left option to put photo to the left. You will need to adjust the Width, Height, Vspace and Hspace options until you get the desired look. The red box with the X give you an idea of where the image will be.
Hope this helps.
Hi Dennis,My photos are attachments and dont show up in the attribute field. Do I need to enable anything or run a tool?
So Dennis, Beatriz's question about how to handle the pics when they are attachments is the same situation I have, can you elaborate on that process ?? That would be most helpful.
Jarrett Livesey
At least in the JavaScript 3.x Dashboard and Web Maps, it does not appear that you can include attachment photos directly embedded in the dashboard lists. I think Dennis' example has a manually calculated attribute at the parent feature-level (which has to be manually updated as attachments change). There is a way to include a link to the attachments in the lists. Though it's not the most elegant solution because it takes the users to the REST endpoint in a new browser tab.
URL is determined from the REST endpoint of the map service (I used "QueryAttachments" to determine the URL)
https://[[myportal.domain.com]]/server/rest/services/[[foldername]]/[[featureservicename]]/FeatureServer/[[layernameID]]/{OBJECTID}/attachments/{ATTACHMENTID}
The [[bold]] items above will differ for your environment.
Hi BrianFausel,
Do you happen to have the full text that you put in the URL input in the screenshot?
Looking what is after {ATTACHMENT....
Thank you!
Advanced formatting in List options shows the new Attachment Arcade function, but it is greyed out... maybe this means they are working on allowing it soon ?
@dzahsh Attachments in a list element still seems not possible.....?
One workaround we found is to create a new Experience using Experience Builder and use the "List" widget which allows for image attachments to be displayed in the list.
@ISP_graynic Would you be willing to share the details of your workaround using the List widget?
@KimberlyK In Experience Builder, when you add a "List" widget you can add an attachment that is connected to the data to the list for each entry and then populate it in the image settings. Here is a screenshot. Let me know if that helps!
