Hi Dag,Apologies for the late reply šThe ability to select a projection for your QuickProject only applies to Default QuickProjects.Any QuickProject Templates - custom or included with ArcPad - cannot be re-projected when creating a QuickProject.The Projections Icon should be disabled when Templates other than the Default QuickProject have been selected.I would suggest creating 2 templates, each with a different projection to include as QuickProject Templates if your project covers different zones.Thanks,Hannah
Hi Dag,If you want to be able to specify a projection for your QuickProject (regardless of the Template used) you must ensure the following: No layers are open and in the map at the time of QuickProject creation eg. create the QuickProject when you first open ArcPad. If any layers are already open, only the existing map projection can be used. Try closing and opening ArcPad, then create your QuickProject!Let me know if this works,Hannah
