All,I have developed an AddIn for ArcMap 10.1 using VB .net 2010.My tool writes data it creates to a dBase file which gets loaded into the TOC. During processing the tool can create up to 25 fields.Sometimes a user will need to rebuild this table with its initial set of 3 fields (by selecting a button on toolbar).When the user clicks on the create table button my code searches for the table in the TOC and removes it with the following code: pStandAloneTableCollection.RemoveStandaloneTable(pStandAloneTable) pMXDocument.UpdateContents()
The code then continues by deleting the existing dBase file and then recreates with the default set of 3 fields. This all works fine. The table is loaded back into the TOC with the following code:pStandAloneTable = New StandaloneTableClass pStandAloneTable.Table = pTable pStandAloneTable.Name = Me.TextBox1.Text pStandAloneTableCollection.AddStandaloneTable(pStandAloneTable) pMXDocument.UpdateContents()
If I then go to the Table in ArcMap and open it I see all the previous fields (with zero values) and not an attribute table with just 3 fields. It's as if ArcMap has held onto the schema of the table it had removed, any ideas on how to force a refresh?Duncan
