Hello,I have a map that implements the Identify Task, where a user clicks on a feature and information appears in a datagrid. The problem is that now when I go to measure something using the Measurement Widget, the line being measured does not show up and features are being selected instead of measured. I am sure it has something to do with an OnClick Event, but I am not sure how to differentiate between the two?Any suggestions would be gretly appreciated!![CODEvar measurement = new esri.dijit.Measurement({ map: map }, dojo.byId('measurementDiv')); measurement.startup(); ]
var measurement //Create Measurement Tool createMeasure(); function tglMeasurementOff() { measurement.destroy(); } function tglMeasurementOn() { createMeasure(); } function createMeasure(){ measurement = new esri.dijit.Measurement({ map: map }, dojo.create('measure')); dojo.place(measurement.domNode,dojo.byId('measurementDiv')); measurement.startup(); measurement.setTool("distance", true); } <div id="map" dojotype="dijit.layout.ContentPane" class="roundedCorners" region="center" style="position:relative; overflow:hidden;"> <button id="tglMeasurementOff" type="button" onclick="tglMeasurementOff();">toogleMeasurementOff</button> <button id="tglMeasurementOn" type="button" onclick="tglMeasurementOn();">toogleMeasurementOn</button> <div id="ovWin" class="shadow" style="position:absolute; right:35px; bottom:35px; z-Index:998; width:100px;height:100px; "> <div id="overviewDiv" style="width:100%;height:100%;"> </div> </div> <div style="position:absolute; left:50px; top:10px; z-Index:99;"> <button id="dropdownButton" iconClass="bingIcon" label="Basemaps" dojoType="dijit.form.DropDownButton"> <div dojoType="dijit.Menu" id="utMenu"></div> </button> </div> </script> <div style="position:absolute; right:20px; top:10px; z-Index:999;"> <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'"> <div id="measurementDiv"></div> <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span> </div> </div> </div>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Identify Sample</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript">djConfig = { parseOnLoad:true }</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script> <style> html, body { height: 98%; width: 98%; margin: 0; padding: 5px; } </style> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.tasks.identify"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.TabContainer"); dojo.require("dijit.form.Button"); dojo.require("esri.dijit.Measurement"); var map, identifyTask, identifyParams, symbol; var layer2results, layer3results, layer4results; var measurement; function init() { var initExtent = new esri.geometry.Extent({"xmin":-9270392.071487641,"ymin":5247043.693206084,"xmax":-9269914.340060795,"ymax":5247401.99177622,"spatialReference":{"wkid":102100}}); map = new esri.Map("mapDiv",{extent:initExtent}); dojo.connect(map, "onLoad", initFunctionality); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); map.addLayer(basemap); var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer",{opacity:.20}); dojo.connect(map.infoWindow, "onShow", function() { dijit.byId("tabs").resize(); }); map.addLayer(landBaseLayer); } function initFunctionality(map) { measurement = new esri.dijit.Measurement({ map: map }, dojo.byId('mdiv')); measurement.startup(); dojo.connect(map, "onClick", doIdentify); identifyTask = new esri.tasks.IdentifyTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer"); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0,2]; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; map.infoWindow.resize(415, 200); map.infoWindow.setContent(dijit.byId("tabs").domNode); map.infoWindow.setTitle("Identify Results"); symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25])); } function doIdentify(evt) { var measureMode = dojo.query(".esriButton .dijitButtonNode").some(function(node, index, arr){ if(node.childNodes[0].checked){ //at least one of the measure tools is active so disable identify return true; } }); if(! measureMode){ map.graphics.clear(); identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; identifyTask.execute(identifyParams, function(idResults) { addToMap(idResults, evt); }); } } function addToMap(idResults, evt) { bldgResults = {displayFieldName:null,features:[]}; parcelResults = {displayFieldName:null,features:[]}; for (var i=0, il=idResults.length; i<il; i++) { var idResult = idResults; if (idResult.layerId === 0) { if (!bldgResults.displayFieldName) {bldgResults.displayFieldName = idResult.displayFieldName}; bldgResults.features.push(idResult.feature); } else if (idResult.layerId === 2) { if (!parcelResults.displayFieldName) {parcelResults.displayFieldName = idResult.displayFieldName}; parcelResults.features.push(idResult.feature); } } dijit.byId("bldgTab").setContent(layerTabContent(bldgResults,"bldgResults")); dijit.byId("parcelTab").setContent(layerTabContent(parcelResults,"parcelResults")); map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint)); } function layerTabContent(layerResults, layerName) { var content = ""; switch (layerName) { case "bldgResults": content = "<i>Total features returned: " + layerResults.features.length + "</i>"; content += "<table border='1'><tr><th>ID</th><th>Address</th></tr>"; for (var i=0, il=layerResults.features.length; i<il; i++) { content+="<tr><td>"+layerResults.features.attributes['PARCELID']+" <a href='#' onclick='showFeature(" + layerName + ".features[" + i + "]); return false;'>(show)</a></td>"; content+="<td>"+layerResults.features.attributes['Full Site Address']+"</td>"; } content+="</tr></table>"; break; case "parcelResults": content = "<i>Total features returned: " + layerResults.features.length + "</i>"; content += "<table border='1'><tr><th>ID</th><th>Year Built</th><th>School District</th><th>Description</th></tr>"; for (var i=0, il=layerResults.features.length; i<il; i++) { content+="<tr><td>"+layerResults.features.attributes['Parcel Identification Number']+" <a href='#' onclick='showFeature(" + layerName + ".features[" + i + "]); return false;'>(show)</a></td>"; content+="<td>"+layerResults.features.attributes['Residential Year Built']+"</td>"; content+="<td>"+layerResults.features.attributes['School District Description']+"</td>"; content+="<td>"+layerResults.features.attributes['Property Description']+"</td>"; } content+="</tr></table>"; break; } return content; } function showFeature(feature) { map.graphics.clear(); feature.setSymbol(symbol); map.graphics.add(feature); } dojo.addOnLoad(init); </script> </head> <body class="claro"> Click the map to identify building and tax information. <div id="mapDiv" style="width:800px; height:600px; border:1px solid #000;"></div> <!-- info window tabs --> <div id="tabs" dojoType="dijit.layout.TabContainer" style="width:385px;height:150px;"> <div id="bldgTab" dojoType="dijit.layout.ContentPane" title="Buildings"></div> <div id="parcelTab" dojoType="dijit.layout.ContentPane" title="Tax Parcels"></div> </div> <div id='mdiv'>My test div area</div> </body> </html>
