Can somebody help me understand how to use the classBreaks function under esri/renderers/smartMapping/statistics in JS API 4.5? The documentation gives an example but I cannot figure out how to feed the results into the classBreaksRenderer.
I've pasted my JS code below that contains a modification of the code example plus my attempt to feed the output from classBreaks into a renderer. I know it's wrong but I'm not clear how to fix it. Any help would be appreciated.
require([
'dojo/dom',
'dojo/number',
'dojo/on',
'esri/Map',
'esri/views/MapView',
'esri/layers/FeatureLayer',
'esri/renderers/smartMapping/statistics/classBreaks',
'dojo/domReady!'
], function(dom, number, on, Map, MapView, FeatureLayer, classBreaks) {
// Create the Map element
var map = new Map({
basemap: 'oceans'
var viewProperties = {
center: [-77.3936, 35.1377],
zoom: 8
// Create the MapView element that will hold the map
var view = new MapView({
container: "viewDiv",
map: map
view.center = viewProperties.center;
view.zoom = viewProperties.zoom;
var renderer = {
type: 'class-breaks',
field: 'Alligator'
renderer.addClassBreakInfo(breakInfos);
function genClassBreaks () {
classBreaks({
layer: featureLayer,
field: "Alligator",
classificationMethod: "quantile",
numClasses: 4
}).then(function(response){
var breakInfos = response.classBreakInfos;
var featureLayer = new FeatureLayer({
url: "https://services.arcgis.com/ycIuRaoIC4UuCDAS/arcgis/rest/services/Alligator%20Sightings%20by%20County%20in%20NCSU%20Survey/FeatureServer/0",
renderer: renderer,
outFields: ["*"],
definitionExpression: "Alligator > 0"
// Add featureLayer to the map
map.add(featureLayer);
