If you want to use a fill symbol with a map point you have first to convert the map point to a polygon or envelope geometry (that support fill symbol).Something like:var env = new Envelope(point.X - 1000, point.Y - 1000, point.X + 1000, point.Y + 1000) { SpatialReference = point.SpatialReference }; graphic = new Graphic() { Geometry = env, Symbol = LayoutRoot.Resources["DefaultFillSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol }; graphicsLayer.Graphics.Add(graphic);That being said I am not sure you need this conversion, if you are identifying 'States' or 'Counties' you shoud directly get polygon geometries.
Yep you are correct i am using geomentary as Map point, but i don't want to use simplemarkersymbol. I need to use fill symbol.If we have mappoint as geomentary then how can we use fill symbol. could you please guide me in this.
If Marker and Line Symbol worked, then maybe the IdentifyResults.Feature is Point or Polyline geometry.Maybe you can determine the geometry type before you set the symbol. Something like: foreach (var result in e.IdentifyResults) { Symbol symbol = null; if (result.Feature.Geometry is MapPoint) symbol = this.LayoutRoot.Resources["RedMarkerSymbol"] as Symbol; else if (result.Feature.Geometry is Polyline) symbol = this.LayoutRoot.Resources["RedLineSymbol"] as Symbol; else if(result.Feature.Geometry is Polygon) symbol = this.LayoutRoot.Resources["RedFillSymbol"] as Symbol; }
