I need it in javascript as all my codes are in javascript and html. I am not using C#.
That why I said you'd have to port it, i.e. from C# to JavaScript.Have you looked at the code? It's not that complicated.
Ya I have seen the codes inside the file. They have something called the Path inside. What do I change the Path to? Polyline?
Maybe....you could do a little research, find out what a "Path" (in that context) is and then relate it to the classes available in the JS API.Here's somewhere to start:http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/002m/002m0000045n000000.htmWhich might lead you to:http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/polyline.htm#addPath
function check(){ alert("stage 1"); //alert("\nCompressed geometry with no Ms, no Zs:"); //PrintPath(CreatePathFromCompressedGeometry("+1m91-6fkfr+202tp+k+f+7+3+34+2d")); //alert("\nCompressed geometry with both Ms, Zs:"); //PrintPath(CreatePathFromCompressedGeometry("+0+1+3+1+emjd+3j07m+3+0+0+1-3-1|+9og+0+lv4+0+lv4|+5rg+uq+r9+au+168")); PrintPath(CreatePathFromCompressedGeometry("+1+hrt+139j+0+0")); } function PrintPath(pth){ alert("stage 5"); //alert(pth); for (i = 0; i < pth.length; i++){ var p = pth; alert(p); //PointN p = pth.PointArray as PointN; //alert(p.x + ",\t" + p.y); } } function CreatePathFromCompressedGeometry(compresedGeometry){ alert("stage 2"); var points = []; var nIndex = 0; var dMultBy = parseFloat(ExtractInt(compresedGeometry, nIndex)); // exception var nLastDiffX = 0; var nLastDiffY = 0; var nLength = compresedGeometry.length; // reduce call stack while (nIndex != nLength) { // extract number var nDiffX = ExtractInt(compresedGeometry, nIndex); // exception var nDiffY = ExtractInt(compresedGeometry, nIndex); // exception // decompress var nX = nDiffX + nLastDiffX; var nY = nDiffY + nLastDiffY; var dX = parseFloat(nX / dMultBy); var dY = parseFloat(nY / dMultBy); // add result item var point = new esri.geometry.Point(dX, dY, new esri.SpatialReference({ wkid: 3414 })); //point.x = dX; //point.y = dY; points.push(point); // memory exception // prepare for next calculation nLastDiffX = nX; nLastDiffY = nY; } return points; } function ExtractInt(src, nStartPos) { alert("stage 3"); // Read one integer from compressed geometry string by using passed position // Returns extracted integer, and re-writes nStartPos for the next integer var bStop = false; var result = ""; var nCurrentPos = nStartPos; while (!bStop) { var cCurrent = src[nCurrentPos]; if (cCurrent == '+' || cCurrent == '-' || cCurrent == '|') { if (nCurrentPos != nStartPos) { bStop = true; continue; } } result += cCurrent; nCurrentPos++; if (nCurrentPos == src.length) // check overflow bStop = true; } var nResult = 0; if (result.length != 0) { nResult = FromStringRadix32(result.toString()); nStartPos = nCurrentPos; } return nResult; } function FromStringRadix32(s) { alert("stage 4"); // Sample input and output: +1lmo -> 55000 var result = 0; for (i = 1; i < s.length; i++) { var cur = s; //Assert.IsTrue((cur >= '0' && cur <= '9') || (cur >= 'a' && cur <= 'v'), "Cannot parse CompressedGeometry"); if (cur >= '0' && cur <= '9') result = (result << 5) + parseInt(cur) - parseInt('0'); else if (cur >= 'a' && cur <= 'v') result = (result << 5) + parseInt(cur) - parseInt('a') + 10; //else Assert.Fail("Cannot parse CompressedGeometry"); } if (s[0] == '-') result = -result; return result; }
Primitive arguments in JavaScript are passed by value so in your code nIndex will always be zero, hence your infinite loop.Are you getting this from a RouteTask? You know that this is decompressed for you in the RouteResult etc?
Do you want to share your javascript port? Maybe on gist.github.com?
