Hi folks,
I've got the same issue with .NET SDK 10.2.4. I'm able to create HydrographicS57Layer with the default color scheme. But I can't figure out how to apply HydrographicS52DisplayProperties. Neither the HydrographicS57Layer nor the MapView or Map have appropriate Properties to set. Any help would be highly appreciated.
Eugen
private HydrographicS57Layer CreateENCLayer(string pathToENC)
HydrographicS57Layer hydroLayer = new HydrographicS57Layer()
Path = pathToENC
HydrographicS52DisplayProperties displayProperties = HydrographicS52DisplayProperties.Default;
displayProperties.ColorScheme = S52ColorScheme.DayWhiteBack;
return hydroLayer;
Eugen, have you checked the DisplayProperties sample on ArcGIS Runtime for .NET Samples?
Edit:
You should be able just to set values to HydrographicS52DisplayProperties.Default instance and those should be reflected to the map. If you see issues with this, could you provide a repro application so I could have a look?
In future, please use ArcGIS Runtime SDK for .NET place for .NET specific questions.
Hi Antti,
I've checked the sample you mentioned. I didn't know that I need to set the DataContext of the MapView to HydrographicS52DisplayProperties. Now it works fine.
Thanks a lot!
For those who are interested:
displayProperties.ColorScheme = S52ColorScheme.DayBright;
displayProperties.DisplayDepthUnits = S52DisplayDepthUnits.Meters;
<!--MainMapView ist the XAML-Name of my MapView (<esri:MapView x:Name="MainMapView") -->
MainMapView.DataContext = displayProperties;
