.rotated270 { transform:rotate(270deg); -ms-transform:rotate(270deg); /* IE 9 */ -moz-transform:rotate(270deg); /* Firefox */ -webkit-transform:rotate(270deg); /* Safari and Chrome */ -o-transform:rotate(270deg); /* Opera */ }
map.infoWindow.setTitle("Identify Results"); //map.infoWindow.setContent(tc.domNode); if( (theLayerName != "Underground") && (idResults.length < 5) ) { // alert("less than 5 records"); map.infoWindow.resize(360, 200); dojo.query(".infowindow").removeClass("rotated270"); map.infoWindow.setContent(tc.domNode); } else if ( (theLayerName != "Underground") && (idResults.length >= 5) ) { // alert(">= 5 records"); map.infoWindow.resize(900, 425); dojo.query(".infowindow").addClass("rotated270"); map.infoWindow.setContent(tc.domNode); // tc = tcLarge; }
map.infoWindow.setTitle("Identify Results"); //map.infoWindow.setContent(tc.domNode); if( (theLayerName != "Underground") && (idResults.length < 5) ) { // alert("less than 5 records"); map.infoWindow.resize(200, 360); // narrower for less records map.infoWindow.setContent(tc.domNode); } else if ( (theLayerName != "Underground") && (idResults.length >= 5) ) { // alert(">= 5 records"); map.infoWindow.resize(360, 200); // wider for more records // map.infoWindow.orientation == 270; <- use = instead of == to set variable. This was causing your error. map.infoWindow.setContent(tc.domNode); // tc = tcLarge; }
