I've been looking into a javascript example that add graphics features on a map as you draw them: Add graphics to a map | ArcGIS API for JavaScript 3.31
Is it possible to do the same thing in Qt or QML? I want to draw a retangular shape by mouse drag to select multiple features at once and haven't found a similar example.
Any help is appreciated. Thanks!
You should be able to do this still. Here is some code that should get you on the right track:
<SPAN class="keyword token">import</SPAN> QtQuick <SPAN class="number token">2.6</SPAN> <SPAN class="keyword token">import</SPAN> QtQuick<SPAN class="punctuation token">.</SPAN>Controls <SPAN class="number token">2.2</SPAN> <SPAN class="keyword token">import</SPAN> QtQuick<SPAN class="punctuation token">.</SPAN>Layouts <SPAN class="number token">1.3</SPAN> <SPAN class="keyword token">import</SPAN> Esri<SPAN class="punctuation token">.</SPAN>ArcGISRuntime <SPAN class="number token">100.7</SPAN> ApplicationWindow <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> appWindow width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">800</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">600</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Untitled123"</SPAN> property bool mouseAccepted<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">!</SPAN>freePanButton<SPAN class="punctuation token">.</SPAN>checked property <SPAN class="keyword token">var</SPAN> startPoint property <SPAN class="keyword token">var</SPAN> endPoint <SPAN class="comment token">// add a mapView component</SPAN> MapView <SPAN class="punctuation token">{</SPAN> anchors<SPAN class="punctuation token">.</SPAN>fill<SPAN class="punctuation token">:</SPAN> parent <SPAN class="comment token">// set focus to enable keyboard navigation</SPAN> focus<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN> GraphicsOverlay <SPAN class="punctuation token">{</SPAN> Graphic <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> graphic <SPAN class="punctuation token">}</SPAN> SimpleRenderer <SPAN class="punctuation token">{</SPAN> SimpleFillSymbol <SPAN class="punctuation token">{</SPAN> outline<SPAN class="punctuation token">:</SPAN> SimpleLineSymbol <SPAN class="punctuation token">{</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"red"</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="punctuation token">}</SPAN> color<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"transparent"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> onMousePressed<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> mouse<SPAN class="punctuation token">.</SPAN>accepted <SPAN class="operator token">=</SPAN> mouseAccepted<SPAN class="punctuation token">;</SPAN> startPoint <SPAN class="operator token">=</SPAN> mouse<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> onMousePositionChanged<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> mouse<SPAN class="punctuation token">.</SPAN>accepted <SPAN class="operator token">=</SPAN> mouseAccepted<SPAN class="punctuation token">;</SPAN> endPoint <SPAN class="operator token">=</SPAN> mouse<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">;</SPAN> envBuilder<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setCorners</SPAN><SPAN class="punctuation token">(</SPAN>startPoint<SPAN class="punctuation token">,</SPAN> endPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> graphic<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> envBuilder<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">// add a map to the mapview</SPAN> Map <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> map <SPAN class="comment token">// add the BasemapTopographic basemap to the map</SPAN> BasemapTopographic <SPAN class="punctuation token">{</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> EnvelopeBuilder <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> envBuilder spatialReference<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">.</SPAN>spatialReference <SPAN class="punctuation token">}</SPAN> ColumnLayout <SPAN class="punctuation token">{</SPAN> RadioButton <SPAN class="punctuation token">{</SPAN> id<SPAN class="punctuation token">:</SPAN> freePanButton checked<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN> text<SPAN class="punctuation token">:</SPAN> <SPAN class="token function">qsTr</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Free Pan"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> RadioButton <SPAN class="punctuation token">{</SPAN> text<SPAN class="punctuation token">:</SPAN> <SPAN class="token function">qsTr</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Draw Rectangle"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The JavaScript sample is showing the "SketchEditor". This is something we don't yet have in Runtime but plan on adding. We do have samples that show how to create graphics, but you'll need to do it programmatically - arcgis-runtime-samples-qt/ArcGISRuntimeSDKQt_QMLSamples/DisplayInformation/GOSymbols at master · Esri/arcgis-runtime-sam…
Thank you!
So, right now, there's no way to do it with a mouse drag?
In the geodesic operations example I've seen that a line is draw by a mouse click. Would it be possible to adapt it to draw some sort of shape and them select the features inside it?
I've managed to do a little prototype based on your code.
