<html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Polling places</title> <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } body { background-color: #FFF; overflow: hidden; font-family: "Trebuchet MS"; } #search { display: block; position: absolute; z-index: 2; top: 20px; left: 75px; } #mapCopyright { height: 20px; width: 250px; position: absolute; bottom: 1px; left: 5px; z-index: 0; } </style> <script src="http://js.arcgis.com/3.15/"></script> <script> var map, popup; var locatorUrl = "http://edinburghcouncilmaps.info/locatorhub/arcgis/rest/services/CAG/ADDRESS/GeocodeServer/"; require(["esri/map", "esri/dijit/Popup", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/FeatureLayer", "esri/geometry/Extent", "esri/geometry/Point", "esri/tasks/query", "esri/tasks/locator", "esri/dijit/Search", "dojo/_base/array", "dojo/DeferredList", "esri/arcgis/utils", "esri/graphic", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "dojo/_base/Color", "esri/SpatialReference", "esri/symbols/PictureMarkerSymbol", "esri/InfoTemplate", "esri/config", "dojo/dom-construct", "dojo/domReady!"], function(Map, Popup, ArcGISTiledMapServiceLayer, FeatureLayer, Extent, Point, Query, Locator, Search, arrayUtils, DeferredList, arcgisUtils, Graphic, SimpleMarkerSymbol, SimpleLineSymbol, Color, SpatialReference, PictureMarkerSymbol, InfoTemplate, esriConfig, domConstruct) { popup = new Popup(null, domConstruct.create("div")); popup.resize(180, 200); map = new Map("map", { extent : new Extent({ "xmin" : 324660, "ymin" : 673800, "xmax" : 325650, "ymax" : 674150, "spatialReference" : { "wkid" : 27700 } }), }); var basemapUrl = "http://edinburghcouncilmaps.info/arcgis/rest/services/Basemaps/basemap/MapServer"; var basemap = new ArcGISTiledMapServiceLayer(basemapUrl); map.addLayer(basemap); var infoT = new InfoTemplate(); infoT.setTitle("Your polling station is"); infoT.setContent("${POLLING_PL}<br/>" + "${FULL_AD}<br/>"); var pollingDistricts = new FeatureLayer("http://edinburghcouncilmaps.info/arcgis/rest/services/Misc/INSPIRE/MapServer/28", { mode : FeatureLayer.MODE_SELECTION, infoTemplate : infoT, outFields : ["*"] }); map.addLayer(pollingDistricts); pollingDistricts.hide(); //create search widget for address searching search = new Search({ sources : [{ //Pass in the custom locator to the sources locator : new Locator(locatorUrl), enableSuggestions : false, singleLineFieldName : "LH_ADDRESS", outFields : ["*"], placeholder : "Search addresses", showInfoWindowOnSelect : false, }], map : map, enableSearchingAll : false, }, "search"); search.startup(); //when a result is found, search polling districts and get the map to zoom to the location of the polling station search.on("select-result", showPollingStation); function showPollingStation(evt) { popup.hide(); popup.clearFeatures(); pollingDistricts.clearSelection(); var point = evt.result.feature.geometry; var query = Query(); query.geometry = point; pollingDistricts.selectFeatures(query, pollingDistricts.SELECTION_NEW, function(results) { }); //once polling district found, center the map on the polling station and show name and address in popup pollingDistricts.on("selection-complete", showAddress); } function showAddress(event) { var results = pollingDistricts.getSelectedFeatures(); x = results[0].attributes["X"]; y = results[0].attributes["Y"]; var station = results[0].attributes["POLLING_PL"]; var address = results[0].attributes["FULL_AD"]; console.log("polling station coordinates: " + x + ", " + y + " " + station + ", " + address); //create new point for polling station var pollingStation = new Point([x, y], new SpatialReference({ wkid : 27700 })); popup.setContent(station + "</br> " + address); //center the map on the polling station map.centerAndZoom(pollingStation); symbol = SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 12, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 0]), 2), new Color([255, 0, 0])); newGraphic = new Graphic(pollingStation, symbol); map.graphics.add(newGraphic); //show popup popup.show(pollingStation); } }); </script> </head> <body> <div id="search"></div> <div id="map"></div> <span id = "mapCopyright" style="font-family:arial;color:black;font-size:9px;"> © Crown Copyright and database right. All rights reserved. </br> Ordnance Survey License number 100023420. </span> </body> </html> |
