I tried reproducing this but could not. nbrCircle, nbrWeight, nbrIrregular, etc. produced no results other than to open that particular help topic.
Thanks for testing. It does sound like it is most likely specific to Windows XP.
Thanks, Xander. That sounds like the same issue. I will add your machine's specifications and steps to the bug.
Which operating system are you using?... If you can consistently reproduce it, we'd need to know your system settings....
As a suggestion, which probably doesn't apply to beta, I never use the built-in help but the online help since it separates ArcMap from the help and it is uptodate...for future consideration...in fact esri should consider online help as the first goto, then if no web access, then the online help
