result:Function â?? Function that should be called when the request has completed successfully. Must have the following signature: public function (result:Object, token:Object = null):void;
// variable=reciever layer // function getLayer(layerId:Number):Layer returns some data with type Layer var layer:Layer = myMap.getLayer(layerId); // no variable=reciever // function can not return any value layer.refresh(); // refresh():void
private function SearchSaleTable(tmp:ArrayCollection):Number { cursor = tmp.createCursor(); var t:String = new String; while(!cursor.afterLast) { t = cursor.current.toString(); var saleQueryTask:QueryTask = new QueryTask(); saleQueryTask.url = "my url"; saleQueryTask.showBusyCursor = true; saleQueryTask.useAMF = false; sQuery.where = "SAPROP = '" + t + "'" ; saleQueryTask.execute(sQuery, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):void { nsum = 0; for each (var g:Graphic in featureSet.features) { nsum += g.attributes.SAPRICE; } trace("on Result " + nsum); sumSaleValue = sumSaleValue + nsum; } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString()); } cursor.moveNext() } return sumSaleValue; }
private function SearchSaleTable(tmp:ArrayCollection):Number { trace(">>>start of SearchSaleTable()"); ... ... trace("query send") saleQueryTask.execute(sQuery, new AsyncResponder(onResult, onFault)); ... ... function onResult(featureSet:FeatureSet, token:Object = null):void { trace("result recieve"); ... ... trace(">>>end of SearchSaleTable()"); return sumSaleValue;
SearchSaleTable(PinArray); // send array to function trace("The very last value " + nsum); private function SearchSaleTable(tmp:ArrayCollection):Number {[INDENT]// loops thru the pin's to search Sale table [/INDENT] [INDENT] cursor = tmp.createCursor();[/INDENT] [INDENT]var t:String = new String;[/INDENT] [INDENT]while(!cursor.afterLast)[/INDENT] [INDENT]{ [/INDENT] [INDENT=2]t = cursor.current.toString();[/INDENT] [INDENT=2]var saleQueryTask:QueryTask = new QueryTask(); [/INDENT] [INDENT=2] saleQueryTask.url = "my url"; saleQueryTask.showBusyCursor = true; saleQueryTask.useAMF = false;[/INDENT] [INDENT=2]sQuery.where = "SAPROP = '" + t + "'" ; saleQueryTask.execute(sQuery, new AsyncResponder(onResult, onFault)); function onResult(featureSet:FeatureSet, token:Object = null):Number {[/INDENT] [INDENT=3]nsum = 0; <-- put breakpoint here [/INDENT] [INDENT=3]for each (var g:Graphic in featureSet.features)[/INDENT] [INDENT=3]{[/INDENT] [INDENT=4]nsum += g.attributes.SAPRICE; [/INDENT] [INDENT=3]}[/INDENT] [INDENT=3]trace("on Result " + nsum); // both "trace" return correct values.........[/INDENT] [INDENT=3] sumSaleValue = sumSaleValue + nsum;[/INDENT] [INDENT=3]trace("The very last value " + nsum); trace("The very last value " + nsum); trace("on sumSale " + sumSaleValue); [/INDENT] [INDENT=3]return nsum;[/INDENT] [INDENT=2]} [/INDENT] [INDENT=2]function onFault(info:Object, token:Object = null):void {[/INDENT] [INDENT=3]Alert.show(info.toString());[/INDENT] [INDENT=2]} cursor.moveNext() [/INDENT] [INDENT]} [/INDENT] [INDENT]return sumSaleValue; or return nsum <-- put breakpoint here [/INDENT] }
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Eddie Test"> <s:layout> <s:VerticalLayout paddingTop="0" gap="0"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.FeatureSet; import com.esri.ags.Graphic; import com.esri.ags.events.MapEvent; import com.esri.ags.tasks.QueryTask; import com.esri.ags.tasks.supportClasses.Query; import mx.collections.ArrayCollection; import mx.controls.Alert; import mx.events.FlexEvent; import mx.rpc.AsyncResponder; [Bindable] private var nsum:Number = 0; protected function button1_clickHandler(event:MouseEvent):void { var queryTask:QueryTask = new QueryTask(); queryTask.url = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0"; queryTask.useAMF = false; var query:Query = new Query(); query.outSpatialReference = myMap.spatialReference; query.outFields = [ "CITY_NAME", "AGE_UNDER5", "AGE_5_17", "AGE_18_64", "AGE_65_UP" ]; query.returnGeometry = false; query.where = "upper(STATE_NAME) = upper('" + ti.text + "') AND TYPE = 'city'"; //queryTask.concurrency = "last"; queryTask.execute(query, new AsyncResponder(onResult, onFault)); // add the graphic on the map function onResult(featureSet:FeatureSet, token:Object = null):void { nsum = 0; for each (var g:Graphic in featureSet.features) { nsum += g.attributes.AGE_18_64; } trace(nsum); } function onFault(info:Object, token:Object = null):void { Alert.show(info.toString()); } } ]]> </fx:Script> <s:BorderContainer backgroundColor="0x999999" alpha="0.8" width="100%" height="30"> <s:HGroup gap="5" verticalAlign="middle" paddingLeft="30" height="100%" width="100%"> <s:Label fontSize="12" fontWeight="bold" text="State: "/> <s:TextInput id="ti" text="Alaska"/> <s:Button click="button1_clickHandler(event)" label="Search" /> <s:Spacer width="30" /> <s:Label fontSize="12" fontWeight="bold" text="Total Population in {ti.text} from the age of 18 to 64:"/> <s:Label fontSize="12" fontWeight="bold" text="{nsum}"/> </s:HGroup> </s:BorderContainer> <esri:Map id="myMap" openHandCursorVisible="false"> <esri:extent> <esri:Extent xmin="-19385000" ymin="6655000" xmax="-13222000" ymax="13326000"> <esri:spatialReference> <esri:SpatialReference wkid="102100"/> </esri:spatialReference> </esri:Extent> </esri:extent> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> </esri:Map> </s:Application>
