The finder app does not produce the desired Search Results for multiple fields.
My parcel layer has 2 fields "ARN" and "Location"
Using a hosted finder app I set the following parameters.
Find Fields = ARN, Location
Result Display Fields = ARN, Location
While the search will correctly find a parcel using an search entry matching either ARN or Location . . . the results will only produce a list using the first parameter identified in the 'Result Display Fields'. (ARN in this case)
That is, if my search matches a Location entry, the corresponding ARN value is shown in the results, not the corresponding Location for which it matches.
Swapping the parameters produces the same and opposite result . . .
I did have the desired result from the previous template.
I believe this is a bug.
Cheers.
For reference: http://nftwp.maps.arcgis.com/apps/Solutions/s2.html?appid=6bc6425b7c3d47b49ed08adb6e47e7cb
