Can anyone tell me why the following python exported directly from a Geoprocessing Model that works does not work? The error message: arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000530: Value is required
I am replacing tst.dbf with a fresh copy before running it in python.Thank you,Nate# Import arcpy module
import arcpy
# Local variables:
tst_dbf = "C:\\Users\\roth\\Desktop\\MIP_Training\\Outputs\\tst.dbf"
tst_View = "tst_View"
# Process: Make Table View
arcpy.MakeTableView_management(tst_dbf, tst_View, "", "", "OID OID VISIBLE NONE;BKGPIDFP00 BKGPIDFP00 VISIBLE NONE;FREQUENCY FREQUENCY VISIBLE NONE;SUM_area_z SUM_area_z VISIBLE NONE")
# Process: Add Attribute Index
arcpy.AddIndex_management(tst_View, "BKGPIDFP00", "#", "NON_UNIQUE", "NON_ASCENDING")
