Please let me know how to check if any feature has a longitude value that is less than –180.00000 or greater than +180.00000
You could use a python script to get the X,Y coordinates of polylines, polygons and points and then identify negative values. https://pro.arcgis.com/en/pro-app/arcpy/get-started/reading-geometries.htm
We want to perform a check for polylines, polygons and points, if any feature lat/long values not between -180, -90 and 180,90 it should be an error. In the suggested configuration between function not allowing negative values. Please suggest how to configure this check.
We apologize for the late response. Is it a line feature? If you so you can use the Evaluate Polyline Length to check if the feature is within the specified range. Is this your business scenario?
Evaluating segment, part/path, and polyline lengths—Help | ArcGIS Desktop
Does anyone here
No one here to have a look into this.
