namespace SIAW_Geospatial.ViewModels { public class Map_ViewModel : Base_ViewModel { private static ESRI.ArcGIS.Client.Projection.WebMercator mercator = new ESRI.ArcGIS.Client.Projection.WebMercator(); private Map_Model mapModel; public Map_ViewModel() { //models mapModel = new Map_Model(this); updateMapCmd = new RelayCommand(updateMap) { IsEnabled = true }; mapModel.getAirportData(); //populate lists } private ObservableCollection<AirportDataServiceReference.July2010RegScheduledFlightDelaysByOrigin> filteredAirportData; public ObservableCollection<AirportDataServiceReference.July2010RegScheduledFlightDelaysByOrigin> FilteredAirportData { get { return filteredAirportData; } set { filteredAirportData = value; RaisePropertyChanged("FilteredAirportData"); //set the map setGraphicsList(); } } //private GraphicCollection myGraphicsList; //public GraphicCollection MyGraphicsList private ObservableCollection<Graphic> myGraphicsList; public ObservableCollection<Graphic> MyGraphicsList { get { return myGraphicsList; } set { myGraphicsList = value; RaisePropertyChanged("MyGraphicsList"); } } private readonly ICommand updateMapCmd; public ICommand UpdateMapCmd { get { return updateMapCmd; } } private void updateMap() { var query = from c in mapModel.AirportData select c; # region filters if (AirlineListSelectedIndex > 0) //0 is All { string airline = AirlineList.ElementAt(AirlineListSelectedIndex); query = query.Where(c => c.Airline.Equals(AirlineList.ElementAt(AirlineListSelectedIndex))); } if (DestinationListSelectedIndex > 0) //0 is All { query = query.Where(c => c.Destination.Equals(DestinationList.ElementAt(DestinationListSelectedIndex))); } if (ScheduledOperatorSelectedIndex > 0) //0 is No selection (i.e. don't filter by this) { if (ScheduledOperatorSelectedIndex == (int)(OperatorTypes.GreaterThan)) query = query.Where(c => c.Operations.Value > NumScheduledFlights); else if (ScheduledOperatorSelectedIndex == (int)(OperatorTypes.EqualTo)) query = query.Where(c => c.Operations.Value.Equals(NumScheduledFlights)); else if (ScheduledOperatorSelectedIndex == (int)(OperatorTypes.LessThan)) query = query.Where(c => c.Operations.Value < NumScheduledFlights); } if (CancelledOperatorSelectedIndex > 0) //0 is No selection (i.e. don't filter by this) { if (CancelledOperatorSelectedIndex == (int)(OperatorTypes.GreaterThan)) query = query.Where(c => c.No_Canceled.Value > NumCancelledFlights); else if (CancelledOperatorSelectedIndex == (int)(OperatorTypes.EqualTo)) query = query.Where(c => c.No_Canceled.Value.Equals(NumCancelledFlights)); else if (CancelledOperatorSelectedIndex == (int)(OperatorTypes.LessThan)) query = query.Where(c => c.No_Canceled.Value < NumCancelledFlights); } # endregion filters //convert to an observable collection ObservableCollection<AirportDataServiceReference.July2010RegScheduledFlightDelaysByOrigin> tmp = new ObservableCollection<AirportDataServiceReference.July2010RegScheduledFlightDelaysByOrigin>(); foreach (AirportDataServiceReference.July2010RegScheduledFlightDelaysByOrigin data in query) { tmp.Add(data); } FilteredAirportData = tmp; } public void setGraphicsList() { //GraphicCollection glist = new GraphicCollection(); ObservableCollection<Graphic> glist = new ObservableCollection<Graphic>(); SpatialReference sref = new SpatialReference(4326); SolidColorBrush pointColor; foreach (AirportDataServiceReference.July2010RegScheduledFlightDelaysByOrigin data in FilteredAirportData) { //get the right color based on the percent of cancelled flights if (data.Percent_Canceled < 25) pointColor = new SolidColorBrush(Colors.Green); else if ((25 <= data.Percent_Canceled) && (data.Percent_Canceled < 75)) pointColor = new SolidColorBrush(Colors.Yellow); else pointColor = new SolidColorBrush(Colors.Red); Graphic g = new Graphic() { Geometry = new MapPoint((double)data.Longitude, (double)data.Latitude, sref) }; g.Symbol = new SimpleMarkerSymbol() { Color = pointColor, Size = 18, Style = SimpleMarkerSymbol.SimpleMarkerStyle.Circle }; //mouse over data g.Attributes.Add("OriginCity", "Origin City: " + data.City); g.Attributes.Add("Destination", "Destination Airport: " + data.Destination); g.Attributes.Add("PercentCanceled", "Percent of flights Canceled: " + data.Percent_Canceled); //g.Attributes.Add("Lat", "Lat: " + data.Latitude); //g.Attributes.Add("Lon", "Lon: " + data.Longitude); glist.Add(g); } MyGraphicsList = new ObservableCollection<Graphic>(glist); } } }
namespace SIAW_Geospatial.Models { public class Map_Model : Base_Model { private AirportDataServiceReference.AirportDataServiceClient airportDataServiceClient; private ViewModels.Map_ViewModel map_vm; public Map_Model(ViewModels.Map_ViewModel vm) { map_vm = vm; airportDataServiceClient = new AirportDataServiceReference.AirportDataServiceClient(); airportDataServiceClient.GetAirportDataCompleted += new EventHandler<AirportDataServiceReference.GetAirportDataCompletedEventArgs>(airportDataServiceClient_GetAirportDataCompleted); } void airportDataServiceClient_GetAirportDataCompleted(object sender, AirportDataServiceReference.GetAirportDataCompletedEventArgs e) { //set the combo boxes AirportData = e.Result; } public void getAirportData() { airportDataServiceClient.GetAirportDataAsync(); } private ObservableCollection<AirportDataServiceReference.July2010RegScheduledFlightDelaysByOrigin> airportData; public ObservableCollection<AirportDataServiceReference.July2010RegScheduledFlightDelaysByOrigin> AirportData { get { return airportData; } set { airportData = value; RaisePropertyChanged("AirportData"); //to start, set the filtered data to the whole set map_vm.FilteredAirportData = airportData; } } } }
<UserControl x:Class="ArcGISSilverlightSDK.UsingGraphicsSource" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" xmlns:local="clr-namespace:ArcGISSilverlightSDK" > <Grid x:Name="LayoutRoot" Background="White"> <Grid.Resources> <local:Customers x:Key="customers" /> </Grid.Resources> <esri:Map x:Name="MyMap" MouseClick="MyMap_OnMouseClick"> <esri:ArcGISTiledMapServiceLayer Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" /> <esri:GraphicsLayer ID="MyGraphicsLayer" GraphicsSource="{Binding Source={StaticResource customers}, Path=MyGraphicsList}" /> </esri:Map> </Grid> </UserControl>
using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Geometry; using ESRI.ArcGIS.Client.Symbols; using System; using System.ComponentModel; using System.Windows.Controls; using System.Windows.Media; namespace ArcGISSilverlightSDK { public partial class UsingGraphicsSource : UserControl { public UsingGraphicsSource() { InitializeComponent(); } private void MyMap_OnMouseClick(object sender, ESRI.ArcGIS.Client.Map.MouseEventArgs e) { var customer = LayoutRoot.Resources["customers"] as Customers; customer.MyGraphicsList = Customers.CreateNewGraphicCollection(); } } public class Customers : INotifyPropertyChanged { private static readonly ESRI.ArcGIS.Client.Projection.WebMercator mercator = new ESRI.ArcGIS.Client.Projection.WebMercator(); public Customers() { MyGraphicsList= CreateNewGraphicCollection(); } private GraphicCollection _myGraphicsList; public GraphicCollection MyGraphicsList { get { return _myGraphicsList; } set { _myGraphicsList = value; RaisePropertyChanged("MyGraphicsList"); } } public event PropertyChangedEventHandler PropertyChanged; protected void RaisePropertyChanged(string prop) { if (PropertyChanged != null) { PropertyChanged(this, new PropertyChangedEventArgs(prop)); } } internal static GraphicCollection CreateNewGraphicCollection() { var graphicCollection = new GraphicCollection(); var random = new Random(); for (int i = 0; i < 10; i++) { var g = new Graphic { Geometry = mercator.FromGeographic(new MapPoint(random.Next(-180, 180), random.Next(-90, 90))), Symbol = new SimpleMarkerSymbol { Color = new SolidColorBrush(Color.FromArgb(255, (byte)random.Next(0, 255), (byte)random.Next(0, 255), (byte)random.Next(0, 255))), Size = 28 } }; graphicCollection.Add(g); } return graphicCollection; } } }
Graphics="{Binding Source={StaticResource MappingSource}, Path=MappingItems, Mode=TwoWay, Converter={StaticResource mappingsConverter}}"
Binding binding = new Binding("Selected"); binding.Source = mappingItem; binding.Mode = BindingMode.TwoWay; BindingOperations.SetBinding(graphic, Graphic.SelectedProperty, binding);
xmlns:local="clr-namespace:BindableGraphics"> <UserControl.Resources> <esri:SimpleRenderer x:Key="MyBlueRenderer"> <esri:SimpleRenderer.Symbol> <esri:SimpleMarkerSymbol Color="Blue" Size="10" Style="Circle"/> </esri:SimpleRenderer.Symbol> </esri:SimpleRenderer> <local:GraphicsSource x:Key="MyGraphicSource"/> </UserControl.Resources> <Grid x:Name="LayoutRoot" Background="White"> <esri:Map x:Name="MyMap"> <esri:ArcGISTiledMapServiceLayer Url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> <esri:GraphicsLayer ID="MyGraphicsLayer" Graphics="{Binding Source={StaticResource MyGraphicSource}, Path=Graphics}" Renderer="{StaticResource MyBlueRenderer}"/> </esri:Map> </Grid>
