I have a server with ArcGIS Server 10.5 installed. I have a javascript Application that points to that server and have a print functionality using the API PrintTask and all is working good.
Now I'm migrating the application to another server with de ArcGIS Server 10.6. I have the same application point to the ArcGIS Server 10.6 and the PrintTask is not respecting the layers visibility, it is showing only the layers tha was originaly visible on the service (defined in the MXD that I used to publish the service). If I turn a layer on or off in the application it has no effect in the PrintTask result
