The RAS mapper is more trouble than its worth most of the time. It is much easier to do without it as debugging can be time consuming. 1)create a copy of your georas cross sections(not 100% necessary, but its always bad to play around with your finished model files)right click on the cross section file->Data->export data.2)add field to the new cross section file attribute table for each RAS profile you want to map(the default "double" settings work just fine)3) in an edit session,copy in your RAS outputif you have bridges you may need to copy the output to Excel or other database program first to remove the extra lines4)In 3dAnalyst toolbar, Create/Modify Tin->Create Tin from featuresSelect your new cross section file and set it to the appropriate profile for the height data source5)In 3dAnalyst toolbox->TIN Surface->Tin DifferenceThis will create a polygon of your floodplain with 3 values. Above, below and same. Delete the below as this is outside your floodplain.Doing it this way allows you to have more control over the initial floodplain. The RAS mapper only works with whatever was originally in the model instead of what would make sense for mapping. A model cross section wont extend into backwater areas, or other areas where a linear interpolation from model cross sections would incorrectly map flood elevations. This process allows you to modify the mapping cross sections however you want(which is another reason to export them an not use the georas files).
I'm having the same problem. I don't mind which way to use, I just want to delineate the floodplains. But I didn't understand everything you said.Is it that I need to export the results from hecras and once I have it in ArcMap, export the shape containing the cross sections?And then?Could you please explain me a little bit more!!!Thanks in advance
I know this is from a long time ago, but I just recently ran into this same error. I tried many different methods until I figured out a solution. I had my DEMs from a LiDAR and in a .img file. I converted these to a GRID file and it worked. This makes me think that Geo-RAS can't correctly read or deal with the .img file and it has to be a GRID file.
Thanks everybody for the replies and solutions as the different methods did work, it is just that my work wanted it done through RAS Mapping.
Best,
Robbie
Robbie,
How did you do that exactly? I'm kind new at GIS (ver 10.1) and need to delineate the floodplain as well.
Mark
You may be interested in this thread too:
Re: Determine Floodplain: Based on known flood level
For converting the .img file to a GRID, I just used the export feature (right click on the file in ArcGIS table of contents and Data to Export Data). This should give you the option to change the file type to GRID. The rest of it was just using the RAS Mapping tools in HEC-GeoRAS based on my results from HEC-RAS.
Perfect solution, THX!
Robert,
thank you thank you thank you!!! I have been losing my mind regarding this for the past few weeks. I can't believe they haven't included some error trapping to notify the user about this incompatibility. Thanks again.
