I looked and looked but I can't find anything that lets the user to change the parser default to python for label expressions. The default is vb so when I run my arcpy script it list my python expression in the vb which doesn't work because it's in a different language. Can someone help me?
<SPAN class="keyword token">import</SPAN> os
<SPAN class="keyword token">import</SPAN> arcpy <SPAN class="comment token"># if outside ArcMap</SPAN>
<SPAN class="comment token"># inside ArcMap, use "CURRENT" for document name</SPAN>
mxd <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>MapDocument<SPAN class="punctuation token">(</SPAN>r<SPAN class="string token">"C:\Users\aa2zz6\Desktop\test\Untitled.mxd"</SPAN><SPAN class="punctuation token">)</SPAN>
df <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListDataFrames<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">''</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">for</SPAN> lyr <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>mapping<SPAN class="punctuation token">.</SPAN>ListLayers<SPAN class="punctuation token">(</SPAN>mxd<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"P_Meters"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name
<SPAN class="keyword token">if</SPAN> lyr<SPAN class="punctuation token">.</SPAN>supports<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"LABELCLASSES"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> lyr<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">+</SPAN> <SPAN class="string token">" supports label classes"</SPAN>
<SPAN class="keyword token">for</SPAN> lblClass <SPAN class="keyword token">in</SPAN> lyr<SPAN class="punctuation token">.</SPAN>labelClasses<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> lblClass<SPAN class="punctuation token">.</SPAN>className
lblClass<SPAN class="punctuation token">.</SPAN>expression <SPAN class="operator token">=</SPAN> lblClass<SPAN class="punctuation token">.</SPAN>expression <SPAN class="operator token">=</SPAN> <SPAN class="string token">'"{}" + [HOUSENUMBER] + "{}"'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"<CLR red = '255' green = '255' blue = '255'><FNT size = '10'>"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"</FNT></CLR>"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> lblClass<SPAN class="punctuation token">.</SPAN>showClassLabels<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">" Class Name: "</SPAN> <SPAN class="operator token">+</SPAN> lblClass<SPAN class="punctuation token">.</SPAN>className
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">" Expression: "</SPAN> <SPAN class="operator token">+</SPAN> lblClass<SPAN class="punctuation token">.</SPAN>expression
lyr<SPAN class="punctuation token">.</SPAN>showLabels <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="keyword token">del</SPAN> mxd<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
