Yes I believe Georeferencing is for rasters & Spatial Adjustment is for other features.In my quest to do the same thing, even with Spatial Adjustment the features would NOT move. So, ESRI Support told me:The following steps help to fix the issue:1. Create a Feature class in the Geodatabase with unknown spatial reference.2. While creating the feature class import the fields from the original feature class.3. After creating the feature class right click on the feature class and assign the projection by importing the desired projection.4. Right click on the feature class and then click on Load > Load Data.5. Select the feature class to from which you need to load the data.6. Create another feature class in similar manner.7. Register the feature classes as versioned.8. Start Editing and make sure the editing templates are created visible in edit session.9. Create four or more control points and adjust the data.10. This would adjust the data spatially.Also, for doing any editing in SDE Geodatabase, the feature classes and the data set have to be registered as versioned.Good luck.
I have been trying to georeference a Cad drawing to match my raster. When I use the Georeferencing toolbox, the CAD drawing does not appear as a target layer. I used the tool CAD to geodatabase to load the CAD into ArcSDE. It adds to the map fine, but why can I not see it in the layer box to georeference it? If I add the raster to my map, that file will appear, but not the CAD drawing?????Can someone help me?My goal is to overlay the CAD drawing over the aerial.
I am really confused. I wasn't prompted to create a world file. When would you be prompted? Right now, I have the cad file overlayed in my map over the aerial and it is dead on. I am just now sure how to convert the new georeferenced cad into a feature class. I want to be able to bring it into any map and have it overlayed right where it is now. Also,the file indicates that the cad may not be projected correctly since it does not have a projection. I have tried to define a projection from the toolbox, but it gives me an error.I am sorry, I am not understanding what you mean????
Something must be wrong because I cannot see the CAD in the georeferencing layer box. I have added the data and see the image, but it does not allow me to georeference it. I have tried several times.
