I am running a field calculation which is [field A]/[field B]. Some of the values in field B are zero. Is there a script I could use to turn results in the calculation where the denominator is zero into -99 instead of creating an error message?
Put this in the code block:
def my_function(numerator, denominator): if denominator == 0: return -99 else: return numerator/denominator
...and this in the expression below the code block:
my_function(!CHSCH04!,!TOSCH04!)
Make sure you've changed to the Python parser.
Maybe I am messing up the syntax. Here is what I have:
Codeblock:
return -99
else:
PRCHSCH =
my_function( [CHSCH04] , [TOSCH04] )
Still returning an error. Thanks for the help.
Oh, sure, yes I missed that part:
Maybe the result can return just the value of -99 instead of numerator/-99 if the denominator is 0. Rest seems perfect.
Something like:
def my_function(numerator, denominator): if denominator == 0: denominator = -99 return numerator/denominator
Expression:
my_function( !YOUR_NUMERATOR_FIELD!, !YOUR_DENOMINATOR_FIELD! )
