I have a table BuildingTable with building info. There is a field called "Build_num" with characters like B37828 or B2898101 or R29499010C or R29499010C2 that i need to join to a shapefile but the the Shapefile BuildNum has a max of 11 characters like so B3782800000 or B2898101000. so i can't join the table to shapefile.
How can update the BuildingTable field "Build_num" to add trailing zeros to that field?
I tried the following, i added a new filed to insert the new Build numbers with the trailing zeros but nothing happened.
import arcpy
fc = "BluidingPermitsTable"
fields = ('Build_num', 'BuildNum')
with arcpy.da.UpdateCursor(fc, fields) as cursor:
for row in cursor:
if row[0] <= 11:
row[1] = '0' + str(row[0])
cursor.updateRow(row)
Thanks.
