so given the code snippet below, here's the behavior: When I "pick", with the mouse, the address offered by the autoComplete, the function "showResults" does not fire. However when I enter the same exact address and press Enter, the showResults function does fire. And.....after selecting a second address via pressing Enter, the following error message appears on the console: "Geocoder:: stop query" but after successfully finding and zooming to the address. This one has me baffled and it may just be code drunkedness. Thanks in advance, rGibson
<script src="http://js.arcgis.com/3.14/"></script>
<script>
var map;
var geocoder;
var locatorUrl = "http://gisapps.fortsmithar.gov/arcgis/rest/services/Locators/GISCREATOR_AddressPoints_CreateAddressL1/GeocodeServer";
require([
"esri/map", "esri/dijit/Geocoder", "dojo/domReady!"
], function(
Map, Geocoder
map = new Map("map",{
basemap: "topo",
center: [-117.19,34.05], // lon, lat
zoom: 13
var myGeocoders = [{
url: locatorUrl,
////////very important when using custom geocoders
singleLine: "Street"
geocoder = new Geocoder({
map: map,
autoComplete: true,
arcgisGeocoder: false,
geocoders: myGeocoders,
value: "8813 Meadow Dr"
},"search");
geocoder.startup();
geocoder.on("find-results", showResults);
function showResults(results) {
var geom;
geom = results.results.results[0].feature.geometry;
alert(geom);
</script>
