i am trying to switch over to "arcgis pro" ... and i have done some tests on differnt kinds of network analyses (route, OD, service area). each of them worked fine in arc map based on the identical set of input data.
when it came to testing route solver i have got an error message 030212 in arcgis pro, which indicates that the start and/or end points couln't be related to the network.
calculate locations and increasing the "search tolerance" parameter didn't help at all (yes i did run the add locations-commad with "use network location fields" parameter selected !)
the same set of input-data works fine in arcmap with the route-layer properties / network locations / search tolerance set to 1000m.
by the way: does anybody know how to restrict network entry points ... which is done in arcmap via route / layer properties / network locations / finding network locations / snap to - settings.
thx in advance
robert
