Regarding the same issue, I bumped into this because of a lack of knowledge. I kept inputting the general internal server URL rather than the URL thrown by the web connector in the add items menu of ArcGIS Online. It would accept the internal and post the data but not offer the credential storing options below the credential input from the add items menu. Once I used the proper web adapter URL the options appeared.
I'm having the same problem, but I'm going through My Content > Add Item > From the web. It's not prompting me to store.
Thanks for the response.
I have not enabled tokens on the service (as far as I know,ha).
my token endpoint is visible. I have not used tokens in a while since my last app (a Flex viewer) used login/password to secure things. I am trying some different approaches now.
URL to server Server Info
Services are externally visible as long as you log in with a user that has access to the secured folder
certificate is network solutions I believe-- there was an issue way back about AGOL not being able to use them but supposedly that was resolved
It has to be secured with ArcGIS Server Token based security and externally visible on the internet. Can you share the URL to your server? Like this: https://<domain>/ArcGIS/rest/info
Is the token endpoint visible?
https://<domain>/ArcGIS/tokens
Who is your certificate provider? Self-signed certificates are not allowed.
Mike
Jörg Moosmeier
Yes, the service has to be externally visible. There is no way for AGOL to validate the credentials if the service is not visible.
Does it have to be secured on the service level or can it be at the folder level? What if you secure the service/folder after you publish the map-- how can you save credentials? I don't want to republish since I have a lot of popups configured and I do not want to lose all that work
Hi,Are you adding the secure service direct to a map, or referencing it through My Content?Login details can only be saved through My Content. If you add it direct to a map you will always be asked for details.Please find a workflow below:Go to My ContentAdd Item > On the WebPaste in the URL of the basemapArcGIS Online will detect it�??s a secure service and ask you for the credentials and whether you want them stored.Click Add Item to save the service in My ContentGo to the Map tab and create a new mapClick Add > Search for layersSearch for your service nameClick Add to add it to your mapIf you want to use the map as a basemap then rather than clicking Add from the search results you need to click the nameThis open a new dialog box that allows you to �??Use As Basemap�?�The standard basemap is now replaced with your new map serviceRegards,Dave
The level of support for ArcGIS Server has not changed. What version of ArcGIS Server are you running?Thanks,Mike
