Imports System.Data.SqlClient Imports System.Data Imports System.Drawing Imports System.Windows.Forms Imports ESRI.ArcGISExplorer Imports ESRI.ArcGISExplorer.Application Imports ESRI.ArcGISExplorer.Geometry Imports ESRI.ArcGISExplorer.Mapping Imports ESRI.ArcGISExplorer.Data Imports ESRI.ArcGISExplorer.Threading Public Class Form1 ' Initialize constants for connecting to the database ' and displaying a connection error to the user. Protected Const SqlConnectionString As String = _ "Server=Your Server Name;" & _ "DataBase=YourDBName;" & _ "Integrated Security=SSPI" Protected Const ConnectionErrorMessage As String = _ "To run this sample, you must have SQL " & _ "installed. For " & _ "instructions on installing SQL, view the documentation file." Protected didPreviouslyConnect As Boolean = False Protected didCreateTable As Boolean = False Protected connectionString As String = SqlConnectionString #Region "Display data" ' Handles the click event for the Display button. This handler gets the product ' information from the Contact table puts it into a DataSet which is used to ' bind to a DataGrid for display. Custom style objects are used to give the ' DataGrid a nice appearance. Private Sub btnDisplay_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnDisplay.Click If IsNothing(DataGridView1.DataSource) Then Dim strSQL As String = _ "USE YourDBName" & vbCrLf & _ "SELECT * " & _ "FROM dbo.tblGIS" Try ' The SqlConnection class allows you to communicate with SQL Server. ' The constructor accepts a connection string as an argument. This ' connection string uses Integrated Security, which means that you ' must have a login in SQL Server, or be part of the Administrators ' group for this to work. Dim dbConnection As New SqlConnection(connectionString) ' A SqlCommand object is used to execute the SQL commands. Dim cmd As New SqlCommand(strSQL, dbConnection) ' The SqlDataAdapter is responsible for using a SqlCommand object to ' fill a DataSet. Dim da As New SqlDataAdapter(cmd) Dim sqlData As New DataSet() da.Fill(sqlData, "Data") With Me.DataGridView1 .Visible = True .AutoGenerateColumns = False .AlternatingRowsDefaultCellStyle.BackColor = Color.Lavender .BackColor = Color.WhiteSmoke .ForeColor = Color.MidnightBlue .CellBorderStyle = DataGridViewCellBorderStyle.None .ColumnHeadersDefaultCellStyle.Font = New Font("Tahoma", 8.0!, FontStyle.Bold) .ColumnHeadersDefaultCellStyle.BackColor = Color.MidnightBlue .ColumnHeadersDefaultCellStyle.ForeColor = Color.WhiteSmoke .DefaultCellStyle.ForeColor = Color.MidnightBlue .DefaultCellStyle.BackColor = Color.WhiteSmoke End With Me.DataGridView1.DataSource = sqlData.Tables(0) Dim newColumn As Integer = Me.DataGridView1.Columns.Add("ID", "ID") Me.DataGridView1.Columns(newColumn).DataPropertyName = "ID" newColumn = Me.DataGridView1.Columns.Add("Name", "Name") Me.DataGridView1.Columns(newColumn).DataPropertyName = "Name" newColumn = Me.DataGridView1.Columns.Add("Address", "Address") Me.DataGridView1.Columns(newColumn).DataPropertyName = "Address" newColumn = Me.DataGridView1.Columns.Add("City", "City") Me.DataGridView1.Columns(newColumn).DataPropertyName = "City" newColumn = Me.DataGridView1.Columns.Add("State", "State") Me.DataGridView1.Columns(newColumn).DataPropertyName = "State" newColumn = Me.DataGridView1.Columns.Add("Zip", "Zip") Me.DataGridView1.Columns(newColumn).DataPropertyName = "Zip" newColumn = Me.DataGridView1.Columns.Add("X", "X") Me.DataGridView1.Columns(newColumn).DataPropertyName = "X" newColumn = Me.DataGridView1.Columns.Add("Y", "Y") Me.DataGridView1.Columns(newColumn).DataPropertyName = "Y" newColumn = Me.DataGridView1.Columns.Add("Geog", "Geog") Me.DataGridView1.Columns(newColumn).DataPropertyName = "Geog" newColumn = Me.DataGridView1.Columns.Add("Data1", "Data1") Me.DataGridView1.Columns(newColumn).DataPropertyName = "Data1" newColumn = Me.DataGridView1.Columns.Add("Data2", "Data2") Me.DataGridView1.Columns(newColumn).DataPropertyName = "Data2" Catch sqlExc As SqlException MessageBox.Show(sqlExc.ToString, "SQL Exception Error!", _ MessageBoxButtons.OK, MessageBoxIcon.Error) End Try End If End Sub #End Region #Region "Create Layer" 'Add all the elements of the table to the map as notes in a notes folder. Sub btnAddNotes_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnAddNotes.Click Dim mapDisp As MapDisplay = ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay 'create a folder Dim fold As New Folder("SQL Notes") mapDisp.Map.ChildItems.Add(fold) 'get coordinates of 1st selected record Dim strX As String = Me.DataGridView1.SelectedRows(0).Cells("X").Value Dim strY As String = Me.DataGridView1.SelectedRows(0).Cells("Y").Value Dim strName As String = Me.DataGridView1.SelectedRows(0).Cells("Name").Value Dim point As ESRI.ArcGISExplorer.Geometry.Point = ESRI.ArcGISExplorer.Geometry.Point.CreateFromLatitudeLongitude(strX, strY) Dim note As New ESRI.ArcGISExplorer.Mapping.Note(strName, point, ESRI.ArcGISExplorer.Mapping.Symbol.Marker.Pushpin.Blue) fold.ChildItems.Add(note) End Sub Sub btnAddAllNotes_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnAddAllNotes.Click Dim mapDisp As MapDisplay = ESRI.ArcGISExplorer.Application.Application.ActiveMapDisplay 'create a folder Dim fold As New Folder("SQL Notes") mapDisp.Map.ChildItems.Add(fold) For Each dgvr As DataGridViewRow In DataGridView1.Rows Dim strX As String = dgvr.Cells("X").Value Dim strY As String = dgvr.Cells("Y").Value Dim strName As String = dgvr.Cells("Name").Value Dim point As ESRI.ArcGISExplorer.Geometry.Point = ESRI.ArcGISExplorer.Geometry.Point.CreateFromLatitudeLongitude(strX, strY) Dim note As New ESRI.ArcGISExplorer.Mapping.Note(strName, point, ESRI.ArcGISExplorer.Mapping.Symbol.Marker.Pushpin.Blue) fold.ChildItems.Add(note) Next End Sub #End Region Private Sub exitToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles exitToolStripMenuItem.Click Me.Close() End Sub End Class
