Sorry - we tightened up the Spatial Reference requirements when initializing layers - you can still just use a GroupLayer but you need to:
- Open the Map Document (MXD) which only contains a Group Layer
- Open the DataFrame Properties dialog
- Set the property ‘Extent Used by Full Extent Command’
By default it is the ‘Extent of data in all layers’, which is effectively null when the map only contains a GroupLayer.
Cheers
Mike
This is not correct for the .NET Runtime map. I get an error when I use an empty mpk with just an empty GroupLayer in it. It requires an empty feature layer in order for it to be successful.
I used this as a reference when I was trying to figure out why my dynamic layer was failing to be initialized.
Any chance there might be a way to add a truly empty mpk for this purpose to the Runtime map eventually?
