# Import system modules import sys, string, os, arcgisscripting # Create the Geoprocessor object gp = arcgisscripting.create(9.3) # Load required toolboxes... gp.CheckOutExtension("Business") gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Business Analyst Tools.tbx") # Script arguments... for i in range(0,3): print i s = str(i) Input_Store_SHP_File = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Retailers_"+s+".shp" # provide a default value if unspecified print Input_Store_SHP_File Enter_Drive_Times = "3" # provide a default value if unspecified Select_Drive_Time_Polygon_Output_Path = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Result\\Retailers_"+s+".shp" # provide a default value if unspecified # Local variables... Output_Traversed_Streets_Feature_Class = "" # Process: 1 to 20 min Drive Time... #tempEnvironment0 = gp.scratchWorkspace gp.scratchWorkspace = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\" gp.DriveTime_ba(Input_Store_SHP_File, "COMPID", "ALL", Enter_Drive_Times, "Minutes", Select_Drive_Time_Polygon_Output_Path, "", "", "false", "false", "false", "true", "false", "false", Output_Traversed_Streets_Feature_Class) #gp.scratchWorkspace = tempEnvironment0
# --------------------------------------------------------------------------- # TestDT.py # Created on: Mon Jun 21 2010 01:31:26 PM # (generated by ArcGIS/ModelBuilder) # Usage: TestDT <Input_Store_SHP_File> <Enter_Drive_Times> <Select_Drive_Time_Polygon_Output_Path> # --------------------------------------------------------------------------- # Import system modules import sys, string, os, arcgisscripting # Create the Geoprocessor object gp = arcgisscripting.create(9.3) # Load required toolboxes... gp.CheckOutExtension("Business") gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Business Analyst Tools.tbx") # Script arguments... for i in range(0,3): print i s = str(i) Input_Store_SHP_File = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Retailers_"+s+".shp" # provide a default value if unspecified print Input_Store_SHP_File Enter_Drive_Times = "3" # provide a default value if unspecified Select_Drive_Time_Polygon_Output_Path = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\Result\\Retailers_"+s+".shp" # provide a default value if unspecified # Local variables... Output_Traversed_Streets_Feature_Class = "" # Process: 1 to 20 min Drive Time... #tempEnvironment0 = gp.scratchWorkspace gp.scratchWorkspace = "H:\\FINANCE\\Analysis\\ESRI\\Sabita\\NewModel\\Test\\" gp.DriveTime_ba(Input_Store_SHP_File, "COMPID", "ALL", Enter_Drive_Times, "Minutes", Select_Drive_Time_Polygon_Output_Path, "", "", "false", "false", "false", "true", "false", "false", Output_Traversed_Streets_Feature_Class) #gp.scratchWorkspace = tempEnvironment0
