void targetMap_ManipulationDelta(object sender, ManipulationDeltaEventArgs e) { e.Handled = true; if (this.targetMap == null) { return; } if (this.targetMap.Extent == null) { return; } if ((e.DeltaManipulation.Translation.X == 0) && (e.DeltaManipulation.Translation.Y == 0) && (e.DeltaManipulation.Scale.X == 1)) { return; } if ((e.DeltaManipulation.Translation.X != 0) || (e.DeltaManipulation.Translation.Y != 0)) { //Get map center coord MapPoint mapCenter = this.targetMap.Extent.GetCenter(); //convert to screen coord Point screenCenter = this.targetMap.MapToScreen(mapCenter); Point newScreenCenter; newScreenCenter = Point.Subtract(screenCenter, e.DeltaManipulation.Translation); MapPoint newMapCenter = this.targetMap.ScreenToMap(newScreenCenter); this.targetMap.PanTo(newMapCenter); } if (!e.IsInertial) { if (e.DeltaManipulation.Scale.X != 1) { if (targetMap.TouchesCaptured.Count() > 1) { Point currentManipulationOriginScreen = e.ManipulationOrigin; MapPoint zoomCenter = this.targetMap.ScreenToMap(currentManipulationOriginScreen); targetMap.ZoomToResolution(this.targetMap.Resolution / Math.Round(e.DeltaManipulation.Scale.X, 2), zoomCenter); } } } }
Another issue is i'm using the GeoRssLayer to display USGS earthquake data in the Web Mercator projection. I'm using the CollectionChanged event in the GeoRssLayer's Layer property to change the MapPoint geometry. However, my UI freezes a while when i'm adding this layer. I believe it is becaused the CollectionChanged event fires a hundred times which causes the slight freeze...
void targetMap_ManipulationDelta(object sender, ManipulationDeltaEventArgs e) { e.Handled = true; if (this.targetMap == null) { return; } if (this.targetMap.Extent == null) { return; } if ((e.DeltaManipulation.Translation.X == 0) && (e.DeltaManipulation.Translation.Y == 0) && (e.DeltaManipulation.Scale.X == 1)) { return; } Matrix transformationMatrix = new Matrix(); if ((e.DeltaManipulation.Translation.X != 0) || (e.DeltaManipulation.Translation.Y != 0)) { transformationMatrix.Translate(-e.DeltaManipulation.Translation.X, -e.DeltaManipulation.Translation.Y); } if (!e.IsInertial) { if (e.DeltaManipulation.Scale.X != 1) { if (targetMap.TouchesCaptured.Count() > 1) { transformationMatrix.ScaleAt(1/e.DeltaManipulation.Scale.X, 1/e.DeltaManipulation.Scale.Y, e.ManipulationOrigin.X, e.ManipulationOrigin.Y); } } } Envelope en = this.targetMap.Extent; Point screenTopLeft = this.targetMap.MapToScreen(new MapPoint(en.Extent.XMin, en.Extent.YMin)); Point screenBottomRight = this.targetMap.MapToScreen(new MapPoint(en.Extent.XMax, en.Extent.YMax)); Point newScreenTopLeft = transformationMatrix.Transform(screenTopLeft); Point newScreenBottomRight = transformationMatrix.Transform(screenBottomRight); MapPoint newMapTopLeft = this.targetMap.ScreenToMap(newScreenTopLeft); MapPoint newMapBottomRight = this.targetMap.ScreenToMap(newScreenBottomRight); this.targetMap.Extent = new Envelope(newMapTopLeft, newMapBottomRight); }
