Using the following code, I get this error message: "TypeError: ListVersions: Could not open SDE Workspace." import arcpy,os #path to database connections path = "C:\\Documents and Settings\\jwinoker\\Application Data\\ESRI\\Desktop10.0\\ArcCatalog\\" dirs = os.listdir(path) #list of the full paths of SDE databases in Database Connections dbs = [(path + dir) for dir in dirs if dir.endswith(".sde")] for db in dbs: dbName = db.replace(path,"") print(dbName) #print a divider underneath the database Path print("-" * len(dbName)) #for each SDE database, creates a list of its versions versions = arcpy.ListVersions(db) for version in versions: print version # create whitespace between each database and list of versions print("\n")
import arcpy import os #path to database connections path = os.path.join(os.getenv("APPDATA"), r"ESRI\Desktop10.0\ArcCatalog") dirs = os.listdir(path) #list of the full paths of SDE databases in Database Connections dbs = [(os.path.join(path, dir)) for dir in dirs if dir.endswith(".sde")] for db in dbs: dbName = db.replace(path,"") print(dbName) #print a divider underneath the database Path print("-" * len(dbName)) #for each SDE database, creates a list of its versions versions = arcpy.ListVersions(db) for version in versions: print version # create whitespace between each database and list of versions print("\n")
Thanks mzcoyle for the clarification. Do you know off hand if sde connections are stored by default in the "C:\\Documents and Settings\\user\\Application Data\\ESRI\\Desktop10.0\\ArcCatalog\\" folder in XP?
versionList = arcpy.ListVersions(path)
versionList = arcpy.ListVersions(db)
import arcpy,os #path to database connections path = "C:\\Users\\jwinoker\\AppData\\Roaming\\ESRI\\Desktop10.0\\ArcCatalog\\" dirs = os.listdir(path) #list of the full paths of SDE databases in Database Connections dbs = [(path + dir) for dir in dirs if dir.endswith(".sde")] for db in dbs: dbName = db.replace(path,"") print(dbName) #print a divider underneath the database Path print("-" * len(dbName)) #for each SDE database, creates a list of its versions versions = arcpy.ListVersions(db) for version in versions: print version # create whitespace between each database and list of versions print("\n")
sde_dir = os.path.join(os.getenv("APPDATA"), r"ESRI\Desktop10.0\ArcCatalog") sde_list = os.listdir(sde_dir) if sde.endswith(".sde"): print sde
