Has anybody encountered this problem? I have tried using both a datetime object and a string formatted object in the query and neither work in either python or ArcMap. I am trying to select a record by both its GlobalID and a specific time in the GDB_TO_DATE field on a query layer.
Query:
coveyObsvRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="string token">'{1309DFFD-04B3-4F13-9962-C1C378F1F228}'</SPAN>
toDate <SPAN class="operator token">=</SPAN> fromDate<SPAN class="punctuation token">.</SPAN>strftime<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'%Y-%m-%d %H:%M:%S'</SPAN><SPAN class="punctuation token">)</SPAN>
query <SPAN class="operator token">=</SPAN> <SPAN class="string token">"GlobalID = '{0}' and GDB_TO_DATE = '{1}'"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>coveyObsvRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> toDate<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#query prints as GlobalID = '{1309DFFD-04B3-4F13-9962-C1C378F1F228}' and GDB_TO_DATE = '2019-11-18 13:58:04'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>If I select by just using the GlobalID, I can return the records, so it's obviously a problem with the TO_DATE field, but I can't figure it out. I can see the record blatanly in the archive table:
(1:58:04 is really stored as 13:58:04 in the database and you will see as much in the ArcMap select by attributes dialog)
