We have run into into this with our NHDPlus processing with the Esri GRID format.
If we have a raster or do some processing using the spatial reference labeled USA_Contiguous_Albers_Equal_Area_Conic_USGS_version (Esri WKID 102039, SR-ORG:6703) this is saved in Esri grids as NAD_1983_Albers and this label propagates through using map algebra or Copy Raster to other formats (like .tif) that do support the standard label. I posted an incident request on this, I really think the raster tools should sniff out at least some projections on their way out of Esri grid format, which is still the most efficient format to use for some processing. This issue will be become less common with 10.5 and later, which has an update to map algebra which does not save temp rasters through the grid format (it now creates temp rasters using .tif).
This is recorded by Esri as
[NIM058732: When projecting ESRI GRID to 'USA_Contiguous_Albers_Equal_Area_Conic', the resulting projection becomes 'NAD_1983_Albers'.
https://support.esri.com/en/bugs/nimbus/TklNMDU4NzMy
though: the problem exists whenever saving any raster to Esri grid format that is in this projection, not just when projecting!
Example:
Input .TIF, reported from Describe as this (although the tif tags don't seem to have a this label anywhere)
Here's the prj.adf file for this raster when saved to Esri grid format:
Projection ALBERS Datum NAD83 Spheroid GRS80 Units METERS Zunits 100.0 /* NAVD_1988 - VCS# = 5703 Xshift 0.0 Yshift 0.0 Parameters 29 30 0.0 /* 1st standard parallel 45 30 0.0 /* 2nd standard parallel -96 0 0.0 /* central meridian 23 0 0.0 /* latitude of projection's origin 0.0 /* false easting (meters) 0.0 /* false northing (meters)<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
When this grid copied to .TIF (in the .tif tags):
PCS Name = NAD_1983_Albers <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
I've gotten into the habit of using the WKID in Python because the names can be quite inconsistent. Then tools like the Define Projection tool can handle the inconsistencies between the different file formats (we hope, and they usually do -- if the raster format supports the projection).
For example, CONUS Albers USGS version using Esri WKID (found by looking in ArcMap data frame properties): arcpy.SpatialReference(102039)
Hello,I'm looking for insights on why the spatial reference of an IMG raster (it's big, that's why it's in IMG format) displays as 'NAD_1983_Albers' in ArcGIS 10 and 'USA_Contiguous_Albers_Equal_Area_Conic_USGS_version' in ArcGIS 9.3.1. This inconsistency is present in Python SpatialReference objects (both arcpy and arcgisscripting flavors) and in the ArcMap Layer Properties GUI. I can code around it, but it seems like a potential bug. Thanks,Lisa
