Here is the XAML: <esri:Navigation Height="140" Background="SteelBlue" HorizontalAlignment="Left" Margin="0,0,605,344" Name="navigation" VerticalAlignment="Top" Width="176" Foreground="SteelBlue" PanFactor="0.25" IsManipulationEnabled="False" Opacity="1" > <esri:Navigation.Map> <esri:Map MinimumResolution="0.0000000000001" IsLogoVisible="False" WrapAround="True" /> </esri:Navigation.Map> </esri:Navigation> After some more testing it appears that the problem is because the <esri:Navigation.Map> is being set. Once I remove those four lines of XAML it works as your example shows.
Hi Ron,Could you post your XAML/C#?The navigation sample for the SDK has the following XAML:<esri:Map x:Name="MyMap" Extent="-15000000,2000000,-7000000,8000000" WrapAround="True"> <esri:ArcGISLocalTiledLayer ID="myBaseMap" Path="..\\Data\\TPKs\\Topographic.tpk"/> </esri:Map> <esri:Navigation Margin="5" HorizontalAlignment="Left" VerticalAlignment="Bottom" Map="{Binding ElementName=MyMap}" /> And no extra C# is required in the sample.
